Mitsubishi VS-60707 60" Rear Projection Television Logo
Posted on Feb 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi VS-60607 60inch projection TV, cannot turn on
Power button on the remote or the unit cannot turn on the TV. the timer light on the TV flickers on and off quickly and TV will not turn on. HELP!!!
  • 11 more comments
  • tonyomaha Feb 22, 2008
    I did what you suggested; the timer light just started blinking after 5 seconds...still it will not turn on...no code appeared/flashed
  • tonyomaha Feb 23, 2008
    It does not appear that there is any leaking coolant.
    But as for the the blinking lights. What's next.
    It does blink when you hold the menu and input bottons down, like you said.. Is there any way I could find the manual online?
  • tonyomaha Feb 24, 2008
    where can i get the full service manual with part list?
  • tonyomaha Feb 25, 2008
    i received the service manual, now what do i do with it?
    I hae the serice manual. What do i do next?
    where do i find the startup voltages
  • tonyomaha Feb 26, 2008
    where can i find the cathode of diode D970 for 4 DC and others? Where are they located? what page # are they on? or the location on the board?
    there is a couple of bubble on the f901 & f903 fuse, while the f902 & f904 has none.....does it mean that they are bad?
    i don't have the meter, but i'll take it to radio shack tomorrow for testing. do you have any more ideas?
    the code that flashes after pushing down the input and menu buttons: 2 blinks, pause, then 4 blinks.......does mean anything to you?
  • Krschrupp Mar 04, 2008
    I have the same model; I am finding it is a error code: 12 - do you know what this means? Thanks
  • helpme1224 Aug 05, 2008
    the power will not restore fault code of 24
Anonymous
Level 1:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Mar 06, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
5
Helped
1070
Points
I have the same and i am having issues with the screen going dark when its suppposed to be a white screen and the picture is darker than it should be during normal watching of tv. also there is a line at the top(letterbox style) of about 1- 1 1/2 inches......anyone know how to fix this
Sonny Berry
Level 3:
  • Mitsubishi Master 8,617 Answers
  • Posted on Feb 22, 2008
Sonny Berry
Mitsubishi Master
Level 3:
Answers
8617
Questions
Helped
1721654
Points
23750
Push input and menu buttons on the TV and hold them both in together for 5 seconds to see if it flashes a code. The let me know
  • 8 more comments
  • Sonny Berry
    Sonny Berry Feb 22, 2008
    That model is famous for the CRTs leaking coolant onto the chassis. Unplug the set and look at the circuit boards with a strong flashlight. See if you can spot any wet or sticky residule on the chassis from leaking coolant. It should be very easy to spot the leakage if present should be on the upper portion of the circuits closer to the screen directly under the picture tubes. Let me know what you find out.
  • Sonny Berry
    Sonny Berry Feb 23, 2008
    If it doesnt blink any code that means its not going into protective shutdown. Its most likely a power supply problem ether the horizontal or regulator transistors are probaly at fault. Do you have the service manual for this model? I can give you pointes to check, but you will need the service manual. I will post a link where you can get one emailed to you.
    http://servicemanuals.vstore.ca/
  • Sonny Berry
    The link I postedhas the manual for 10.99. Its an older set so its a hard manual to find. Theirs is the full service manual with part list
  • Sonny Berry
    Sonny Berry Feb 25, 2008
    If you go to this link they have the full service manual with parts list and they will email it right out to you . I have used this site many times they have good quality manuals and you recieve them within minutes of placing the order and they also provide free support to help diagnose for free. Check them out you will be glad you did. here is the link.
  • Sonny Berry
    Frst thing is to check the start up voltages. The manual will have the various voltages required. You will need to check for standby voltages and run voltages. They should be outlined in the power supply section of the manual. I will post more specific info this afternoon.
  • Sonny Berry
    Sonny Berry Feb 26, 2008
    Check the cathode of diode D970 for 4 VDC. check Resistor R974 for 32VDC then the cathode of D741 for 18VDC and finally check pin 1 of IC952 for 130VDC Let me know what you find.
  • Sonny Berry
    Page 61 of the manual. the parts arelocated on the main PC board where the power plug entersthe set is the main PC board
  • Sonny Berry
    They could be. Check them for coninuity with an ohms meter if they dont register they are bad.
  • Sonny Berry
    The voltages I mentioned earlier have to be verified if the fuses turn out allright. If those voltages are not right then its a simple task to trace it back to whats preventing the set from operating.Something such as a regulator or diode can mess up the voltages that will prevent the set from powering up.
  • Sonny Berry
    24 Is the code for vertical deflection failure. Thats why your set isnt working. That could just be bad solder on the vertical output IC which is IC451 on the main PC board or you may need a new IC I would try resoldering it first.
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
1helpful
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mitsubishi VS-50609 won't turn on
What a great tv this is Mitsubishi did a fine job making this one, but......only an authorized mitsubishi servicer should repair it. This set records diagnostic led codes that the technician receives to help determine where the problem might be, not the problem, but in which circuit it might be. The one thing to try is, unplug the tv , let it set for a minute, plug it back in , turn it on and hope it reset the micro. Next , call for mits. service.
1helpful
Mitsubishi VS50605 rear projection TV won't come on
The power supply caps in the light engine power supply were faulty when they were installed. You need to remove the power supply and take it to your local electronics shop where they can remove the (7) faulty 1000uf 16v electrolytic capacitors and insert new ones. If you remove the power supply yourself (takes only a philips screwdriver) and reinstall it yourself, the electronics shop shouldn't charge you for more than an hour worth of time. The caps would be about $10.
Here's a photograph (thanks Don Crawford).
Timer light is flashing but tv wont turn on!
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
VS-50609 no picture no sound
Seems to be the power button is stuck on the tv itself
Mitsubishi vs-50609 wont stay powered on
Hello nicolastran,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Unit turns off after 3 seconds
sir i think theres something wrong with the power supply kindly check it out thanks and hope too help you,,,gud luck
2answers
Timer light flashes 3 times
the code means that your tv power supply is not functioning your tv needs to be repaired call the tech.good luck
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
