Yes, it is needed to set the depth of tilling, longer the bar is set the higher the tiller rides. The lower the bar is then the deeper the tiller tries to till.
The bar also helps you manoeuvre the tiller left and right. If you look at the owners manual you can see what it looks like and get one made if it is lost. It will work without the bar but it adds control when rotovating.
an example would be if the ground is hard or it finds some stones the tiller can buck about until breaks through the soil or it removes the stone from its path.
pushing down on the handlebars presses the bar into the soil, the bar lifts the tiller blades from the ground and it will settle down. Without the bar it wil buck until you pull it back away from the stones or into some softer ground and it can start munching into the soil again.
always check spark and compression first spark needs to be blue and compression should be 120 but will barely run on 80psi if both are fine rebuild and acid dip carb
This sounds like it might be a defective CCD imager. If so, Fuji should fix this for you for free. This is regardless of your camera's warranty status. Please check the following two links for more info:
