Hi, I made some videos how to fix your Jura step by step, good luck..http://fixandparts.wix.com/nicknicoloudi...Hi, I made some videos how to fix your Jura step by step, good luck...http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
You can't post conmments that contain an email address.
I have 3 different coffee machines and all 3 are descaling like you said using only the froter so that is normal .... Unless you misstyped the question
The message 'FAULT 5' on the Jura Impressa F7, appears when there is a problem with the heating sensor. Normally it needs service or replacement. You can try to unplug it from the power supply for an hour and then open it again. See if it works.
First you have to turn the machine off and then press and hold rinse buttom until you read empty tray and then follow the rest of the instructions. Good luck
Jura f7
