FL could be a code for low flow. If you have no circulation this sounds like it. If your pump runs and you have no flow you could have a problem with your pump. Or if you have the tub drained then it could be an air lock, if you open the drain valve till you get water out that should fix that. Also check to be sure the isolation valves are open under the spa. I hope this helps.
I just recently had this problem. I cleaned then replaced the filter and also cleared debris from the intake openings in the tub itslef. After turning the pumps on a few times the error cleaed but not right away.
In the QCA Spas owners manual the FL symbol represents low flow in your hot tub. This can occur for many reasons including the following.
Its a good idea to clean or change the hot tub filters and then check the suction areas to remove any debris. You may have an air lock. To remove an air lock just partially open a union near the pump to allow the air to release from the line.
For more information on QCA Spas error codes and information see our guide at The Cover Guy on QCA Spas.
QCA Spas Information and ERROR Code Guide
