Contact the manufacturer Samsung and download a copy!
You can download one from http://www.samsung.com/us
You can download/print your camera manual here:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=04012400&prd_mdl_cd=EC-TL100RBP%2FUS&prd_mdl_name=SAMSUNG+TL100
BillB
SOURCE: My SAMSUNG TL100 CAMERA LENS STUCK OUT SIDE
It seems your camera Lens got stuck in open condition, This will happens due to two reason.
1) Either your camera battery got died or need to be recharged or replace.
or
2) Your camera is malfunctioning and need service (repair).
To resolve the problem. first check battery indicator on your camera, If battery indicator shows battery low, than you need to charge it or you need to replace your battery.
Follow the instruction to retract camera lens:-
1) Turn on your camera.
2) Press the Playback button on the back of your camera. The lens on your camera should retract.
If problem still not resolved then your device need to be serviced (Repair).
Rating the solution is highly appreciated...Good Luck.
SOURCE: I have Samsung TL100 camera. when
Hello there,
Are you sure you battery pack is fully charged? If yes then there is a hardware problem on your camera that's why when the system detected that, it automatically shuts itself off. Usually this is caused by a lens error. The camera cannot retract out the lens because there may be a grit of sand or dust build up in between the lens barrel and the camera. Here is what you try to do:
Hold the camera with your right hand with the lens facing the ground. Then hit the camera's base to your left palm as you turn on the camera. This aims to take off that grit and the lens to retract out. You may need to do this several times.
Please let me know how this goes.
SOURCE: my samsung camera tl100 does
go to samsung website download vista driver for ur camera model
SOURCE: how do you move pictures
Find "copy"in the menu....it usually allows you to do what you need.
