What is the cost of
ASUS ATi Radeon HD5450 1GB GDDR3 (PCI-E) Graphics Card .
or
SAPPHIRE HD 5450 1GB DDR2 PCIE
and where can i buy any of them.
AND which one is better.???
WHAT DOES THIS HDMI,VGA-all MEANS?????
I need to get it in INDIA(shipped to INDIA)
Amazon show a XFX ATI Radeon HD5450 1 GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card HD545XZCH2
For $34
Amazon com XFX ATI Radeon HD5450 1 GB DDR3 VGA DVI HDMI Low Profile PCI...
eBay shows one USED for $19
XFX ATI Radeon HD 5450 HD 545X ZQH2 HD545XZQH2 778656056176 eBay
GOOD LUCK getting a seller to ship to India! Have a friend in the US buy one and let THEM ship to you!
Anthony
SOURCE: Sapphire ATI RADEON 3850 PCIE 512mb
I have a similar problem. Ati Radeon 3850 /512MB on an asus M2N-E motherboard with Nvidia chipset. My computer reboots itself from time to time. Changed memories, cpu, power supply just in case one of theese component might be faulty but no use, same results. Could there really be a conflict between Nvidia and Ati working togehter on the same PC? Tried even to browse the web for ideas and solid ideas concerning this issue but i came to the conclusion that Nvidia chipset doesn't like Ati vcards. Compatibility issues which i don't consider to be normal at all. Any other ideas?
Cheers.
SOURCE: ATI Radeon HD4850 512MB GDDR3 with
you have to go into control panel hardware and sound, now click on sound, you will see speakers with a green check next to it. on top you will see HDMI enable those and hit test button. this is part of device no worry bout bios or motherboard. Just make sure you use the adapter that came with the video card it will only work with the supplied adapter. Not a dvi to hdmi cable. this will work. i hope this helps and good luck. I can coach you more but i am not sure of your operating system. i was coaching you using vista.
Hi there.
Looking at the specs, it could be DDR2/DDR3 or even GDDR3. The best way to find out, is to open your BIOS setup screen when you first turn on the system. It should be listed on the first page that lists what processor your running.
Hope that helps.
Tim
SOURCE: Graphics Comparison
I beleive that your onboard is pretty much the equivelent to the geforce card you have spec-wise. But the 3300 a much new technology and has a faster processing speed in comparison to the geforce 6600 (not sure about the 7200).
In anycase, if you get yourself another ATI HD card (2400, 3450, or 3470) you can actually run them both as a Crossfire set up. Also, you can slight overclock your onboard video just a tad if that is a route you wanted to take.
The HD 3300 onboard was meant to be a better option over more entry level cards on the market today.
If you're still not sure, you can always do a 3dmark or gaming FPS test on each gpu to see which gives you the best outcomes.
SOURCE: my computer won't detect ATI RADEON SAPPHIRE X1550 256MB
go to bios and enable it to detect graphics cards most bios have an option for onboard only or onboard and external graphics adapters
