Unable to reset the auto on (time was set to 4:00 pm) to OFF?
I tried to reset the setting by pressing the Menu, changed the Auto On setting to read Auto Off but when I close the Menu the display reads AutoOnOff and the machine continues to turn on at the preset time.
SOURCE: Keurig Machine Stopped Working
If you can get through the menu and re-set the timer great! This may solve it.
SOURCE: I set the auto off on my new Keurig and it has now
Sorry to read about your problem, I hope this helps you out.
unplug the unit, that should solve your problem..then re program
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
SOURCE: Menu reads "Not Ready" After 5 minutes or so
When you turn it on does it/you go through Prime sequence as detailed in the Manual?
1Press Menu/Set, 0, 2.
2 Enter the last two digits of the year. Press Menu/Set.
3 Enter two digits for the month. Press Menu/Set.
(For example, enter 09 for September, or 10 for October.)
4 Enter two digits for the day. Press Menu/Set.
(For example, enter 06 for 6th.)
5 Enter the time in 24-Hour format. Press Menu/Set.
(For example, enter 15:25 for 3:25 P.M.)
6 Press Stop/Exit.
The LCD now shows the date and time whenever the machine is idle in Fax mode.
When the machine is in Sleep mode, the LCD shows Sleep. (See Sleep Time on page 2-8.)
Hopefully that worked correctly and solved your problem!
