Sounds like the electronics of the motion detector is toast, probably from a voltage surge associated with your power failure. Since you have already used the manual switch, you have already tried the "reboot" option, but here is something else to try (it's a long shot). Turn the manual switch off, remove the light bulbs, turn the switch on for a few seconds, turn it back off, replace the bulbs and try again. Also, in the remote chance that this device uses an electo-mechanical relay (as opposed to all solid-state), the relay may be stuck, you might give it a couple of sharp raps while you have the bulbs out. When you turn it back on (before you put the bulbs back in) you might be able to hear the click of the relay if you go out there and give it some motion to detect. If all this doesn't work, you'll need to replace the unit. They may sell a replacement electronics unit for it. --- good luck.
The fuel pump shut-off switch is
located in the driver's foot well,
behind the kick panel. The reset
button for the fuel pump shut-off
switch is accessible through an
opening in the kick panel.
Use the following procedure to reset the fuel pump shut-off switch.
1. Turn the ignition to the OFF position.
2. Check the fuel system for leaks.
3. If no fuel leak is apparent, reset the fuel pump shut-off switch by
pushing in on the reset button.
4. Turn the ignition to the RUN position. Pause for a few seconds and
return the key to the OFF position.
5. Make a further check for leaks in the fuel system.
The fuel pump inertia switch button will be flush with the switch housing when activated. Just need to depress the switch till you hear a click. You can also test the switch by giving it a sharp tap with your hand. It'll trip the switch when you do.
FUEL PUMP SHUT-OFF SWITCH
If the engine cranks but does not start after a collision, the fuel pump
shut-off switch may have been activated. The ''Fuel Reset'' indicator light
will illuminate in the instrument cluster. The shut-off switch is a device
intended to stop the electric fuel pump when your vehicle has been
involved in a substantial jolt.
1. Turn the ignition switch to the OFF position.
pushing in the button on the switch.
4. Turn the ignition switch to the ON position. Pause for a few seconds
and return the key to the OFF position.
Thanks for your response!
What happened was the power went out, and when the power came back on the lights will not turn off!
I have them on a switch when i turn the switch off and turn back on they still stay on.
The product i am talking about is Heath Zenith
SL-5798
thank you
steven
Steven,
Can you provide a little more information? Have you replaced a switch, or has an existing switch failed? What kind of switch is it?
