HP Officejet 5610 All-In-One InkJet Printer Logo
Posted on Mar 02, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP PHOTOSMART C7180-- CARRIAGE JAM MESSAGE--LOOKED CAREFULLY-NO PAPER-WAS ABLE TO MOVE CARRIAGE TO THE LEFT, BUT WOULD NOT MOVE COMPLETELY TO THE RIGHT--MAKES A GRINDING NOISE--ANY IDEAS? TRIED RESET-DIDN'T WORK-NOW ALL INK CARTRIDGES ARE LISTED AS MISSING AFTER COMPLETING THE RESET.
Scott Yeoman
Level 2:
  • Expert 121 Answers
  • Posted on Apr 01, 2018
Scott Yeoman
Expert
Level 2:
Answers
121
Questions
0
Helped
74847
Points
190
There is a coder strip that the print cartridges ride on that strip needs to be replaced , they seem to run between 10.00 and 20.00 bucks. It is spring loaded one the side and other is fixed, they are semi easy to do. May take a couple of times. Also do not wipe the strip with a wet cloth -code will come off!
5 Related Answers
Lee Eismann
  • 88 Answers
  • Posted on Nov 27, 2008
SOURCE: carriage jam issues on hp printer
So sorry to hear that you are having issues with your C4385 printer. HP's All-In-One printers seem to be very touchy when it comes to carriage jams, and mine is no exception. They are usually caused by little bits of paper left over from a previous jam, so you just have to work out where to find them. HP produced a page with diagrams to help people find them. Please click here to access their solution page.
Hope this helps!
Anonymous
  • Posted on Apr 20, 2009
SOURCE: Carriage Paper Jam in Photosmart hp c6180 all-in-one-printer
Here's what you do. Take a look at the photo below.
Open the cover of the printer, where the ink cartridges are located. Behind the ink cartridges is the carriage, which is a box that moves side-to-side on a pair of rails. It's the thing that sprays the ink onto the paper.
You have to reach in with your hand and slide this thing to the center. Then, look to the very sides, left and right, for any bits of paper. If you look at the second picture, you can see my finger pointing to a small bit of paper that tore of and got jammed into the side. See the little crumpled bit of paper? It's preventing the carriage from sliding all the way to the right. You could have little bits on the right or left side. I had to reach in with needle-nose pliers to grab the paper bits out, but maybe your fingers are small enough.
Once the little bits of paper were out, I was back in business. Good luck!
A
Anonymous
  • Posted on May 04, 2009
SOURCE: carriage jam on HP photosmart 3310 all in one
Here is the actual solution from the HP website for a carriage jam...click on the link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786043&tmp_track_link=ot_faqs/top_issues/en_us/c00786043/loc:12&lc=en&dlc=en&cc=us&product=439491
Anonymous
  • 73 Answers
  • Posted on Jul 19, 2009
SOURCE: printing error oxc18a0101
Try resetting the printer:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on.
Anonymous
  • 61 Answers
  • Posted on Sep 04, 2009
SOURCE: Carriage jam on HP Photosmart D7160. No paper in
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00854650&cc=us&lc=en&dlc=en&product=1156652
HP Photosmart C5580 All-in-One Printer. I can't clear carriage jam on HP 5580 checked for paper jam -- none.
Question edited for clarity, full 'make model (what it is)'.
Question moved to model category.
It is a known issue on that model.
Solved: clear carriage jam on my HP Photosmart C5280
HP Support Community https://h30434.www3.hp.com > td-p
Jul 14, 2017 - I have the same issue. Almost new machine. Screen says "clear carriage jam", but there's no paper jammed in there. Can't do anything with the printer, since ...
clear cartridge jam on photosmart c5280 - HP Community
Aug 29, 2016
Solved: "Carriage Jam" message won't clear despite no paper ...
May 18, 2022
carriage jam on HP photosmart c5550 can't find cause.
Dec 9, 2018
Carriage Blocked Message Photosmart c5280 - HP Community
Sep 3, 2018
More results from h30434.www3.hp.com
A 'Carriage Jam' or 'Carriage Blocked' Message Displays ...
Hewlett-Packard https://support.hp.com > us-en > document
Solution · Make sure the printer is turned on. · Open the print cartridge access door, and then wait until the print carriage is idle and silent. · Press down ...
Fix Carriage Jam Issues
Hewlett-Packard https://support.hp.com > Support home > Printer issues
These jams occur when the carriage holding the ink cartridges stalls in the printer. Carriage jams sometimes occur after a paper jam. Our automated Virtual ... ..
3helpful
2answers
Carriage Jam
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
4helpful
2answers
Error message carriage jam and/or paper jam
Often a carriage jam is caused by a paper jam. If you're getting a carriage jam message and a paper jam message, this video should help.
utube.png You-Tube video "wPjahOY5CDo" placeholder
2helpful
2answers
My HP Officejet 7210 all in one is showing the following error message: Carriage Jam. Open carriage door, clear jam, then press ok". There is no jam, I have looked through the back door and the front of...
Carriage jam means the carriage, where you put the inks, can't move right to left properly. Sometimes ink on the clear strip behind it is the cause. You can carefully clean with damp Q-tip, and check also that the cleaning assembly on the right where the printhead parks, is not stuck.
2helpful
Carriage Jam Message
the multiple pages are from a pickup roller and separation pad which or probably worn down. The Jam error is most likely cause by one or more of the sensor flags these are the plastic usally blak things hanging along the paper path. One of those are either stuck or broken. Check the path and look for those items. And the pickup rollers you should be able to buy and install yourself
Carriage jam
I don't have the same model, but I do have three hp photosmart machines here, and I usually reach in and grab the carriage and give it a little pull and push, once it has moved it will then go to its place. A word of caution, turn off the printer before you try this. Then turn printer back on after closing lid. I think I learned this from one of the manuals or their web site.
2helpful
2answers
HP 6180 printer
henryandjane,
Look over on the wheel that will feed the paper mybe there is a tiny piece of paper on it and find the sensor for the paper mybe it is stack-up already
1helpful
How do I get fix a "carriage jam"?
I was able to run run a piece of photo paper through a couple of times and printer now seems to be working again. The theory was that running a heavy piece of paper through might help clear little piece of paper that was not visible. The photo paper is less likely to tear if it gets jammed too.
4answers
Error code
I'm not able to post a link, but go to the HP homepage and click on the support and troubleshooting link, click on the "all in one" link, click on the "solve a problem" link, click on "errors and lights", click on
k24674
Grand Canyon Tech
Grand Canyon Tech
