I turn my SanDisk on it and it says "Not Enough Space for Music DB.Please free 4MB". Then on the screen it says that there is "No Files" and it doesn't play any songs, though I do have MP3 files that show up when SanDisk plunged into computer. Although there was more than 200MB of free space, I deleted 4MB but it didn't work. Please help me!
Try formatting your device then try to put mp3 files on it. check if it works. on your my computer right click you mp3 device ( it is usually a removable storage) then select format.
When connected to your computer, go to your My Computer folder, and right click on your Mp3 player. You should see "Format Device". This wipes the entire thing. All music will be gone, but it might reset it.
whenever i turn on my sansa m230 mp3 player, it displays the message, "not enough space for music DB, please free 8mb." And so i plug it into my friends computer and when i open the music folder on the device, its empty, even though it says that there is quite a bit of space used up. Do you have any answers?.
I would recommend that you update the firmware on your device..that usually solve the problem you are having..To update the firmware, follow the link below.. http://www.sandisk.com/DriverDownload/download.asp
I hope that helps
Please rate accordingly
Thank You
Computerrep
Try this: disconnect the player from the computer, turn it off,hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
we had that problem and sandisk had us use a file when we plugged it in to our computer to reformat it but I don't remember how exactly how to do it, seems like we connected it and chose a file -sorry
When you delete files on the sandisk it just moves them to an invisable folder labeled .trash inorder to free up some space you need to delete the files inside this invisable folder. if you are using windows then plug in the device and open it. go into you folder options and make sure it has show hidden files selected. If you are using a linux os then go into your view menu and select show hidden files. this should make the .trash folder appear. hope this helps.
