GE WSXH208A Front Load Washer Logo
Anonymous Posted on Feb 06, 2010
GE front load washer wont start model #WHDVH626FWW
The washer control panel works , the water is on , the drain hose is not pinched , The pump is not clogged . but wen you press the start button it just beeps then does nothing
  • Anonymous Feb 06, 2010
    No the little plastic black switch to recognize that the door is closed broke off
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 04, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
839
Points
How do you repair/replace the door lock?
Anonymous
Level 3:
  • Master 1,531 Answers
  • Posted on Feb 06, 2010
Anonymous
Master
Level 3:
Answers
1531
Questions
0
Helped
406881
Points
4453
There is a chance that your door lock has failed
FL GE Adora Washer - WHDVH626FWW, will not spin, clothes come out wet. When I run "rinse and spin", water comes in, but drum only spins initially left half turn, then right half turn, never spins...
Hi Walter:
In oreder your diagnostic, that means that your motor control board has faild and needs to be replaced. This part is located behind the lower front panel. if you remove the screws along the bottom of the lower front panel, you can then pull the panel off and the control board is on the left side with all the wires going into it.
You can replace it yourself if you'd like, you will need to remove the lower front panel to gain access which is probably the hardest part. And you can order the part from Repairclinic.com if you have a full model number if you wanted to.
You need the motor control board. Here is a link to the part for your model number: PartDetail/Control-Board/WH12X10418/1475761
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
7helpful
I have a GE front loading washing machine. it will not drain model is wsxh208
Hello there:
This is due to the drain pump being clogged
The drain plug is on the front of this washer - you can see it without removing anything - there is a small 5"x3" panel on the front bottom that you pull out and then the plug twists free - have a large pan ready and unsrew slowly - water will come gushing out - have towels at the ready!
There are 2 screws on the bottom of the larger bottom front panel - remove these and you can see inside
you will see the drain plug housing is connected to the water pump and there are two hoses connected to the housing and the pump one coming from the washer to the drain plug and one going from the pump to your drain.
Remove the hoses carefully - I used plyers to pinch the clamps together.
the hardest part of this is removing the drain plug housing and pump - because it seems like you should be able to just remove the pump - but you can not!!
There are two screws holding in the housing and pump - remove them and the whole thing pulls clear.
Once out you can make sure there is not more coins or **** in the thing. Three screws hold the housing to the pump - mark these with a sharpie before you remove them - because once it is off there are multiple ways to re attach it.
Once free of the drain plug housing spin the pump a few times and put it all back together -
Hope this is very helpful for you
Best regards Mike
1helpful
My washer will not drain
Hello there:
I would check the drain pump for a clog. Remove the front panel of the washer, the pump is at the front bottom right side, with 2 hoses attached. Now either get the water out of the tub with a shop vac, or pinch off the hose connecting the tub to the drain pump. Take the top hose off, and stick your finger down the hole and feel for anything. also you can stick a screw driver down the pump and see if the impeller moves freely...
Read more: http://forum.appliancepartspros.com/washer-repair/8486-ge-washer-will-not-drain-spin.html#ixzz10rBUaUUw
6helpful
GE front load washer is not draining after spin cycle
The draining is controlled by drain pump in the washing machine. If the drain pump is clogged or got loose then water will not drain properly and this problems will occur.Remove the drain pump and drain hoses. First thing you can do is take the drain hose and blow into it and check if its getting blocked.If the air is passing through the hoses then loosen the hoses to the pump. You might want to get some pinch off pliers to save water from going ever where or a shop vac to **** out the tub. If the pump is getting warm current is flowing to it and propeller is jammed more than likely. The front should have a couple of 1/4 screws at the corners on the front should pop after removing them. If you require parts then you can buy them from www.repairclinic.com Thanks. you can rate this solution and show your appreciation.
3helpful
My GE front load washer model # WHDVH626fww wont run . The display works the door is shut the water is on but it just beeps when you pres the start button
we had that same problem too with a few others, had repair guy come out and all he had to do was cean out the drain that is behind the bottom panelof the washer, as you look at washer you will have 3 screws to take out and panel will come off, drain plug is on right side you can't miis it. make sure you have pan for water. clean it and it should help. it worked with ours.
good luck.
it cost us 121 dollars for that
2answers
My washer wont drain
The washer's pump unit has stopped working. It may not me getting the signal to pump after the wash cycle (controller problem) or the pump has let go and needs to be replaced.
Wont drain
you will have to take the front cover off. you will see a clip on the top right and left side at the seam at the top of the front cover. you can tale a screw driver or putty knive and push down on the clips and the front will pull off toward you. unplug the machine. you will see the drain pump at the front bottom right, the pump may be hung up. try turning the fan on the pump to free it up. if this does not work change pump. if water is in machine you will need to pinch off hose comming from tub if you change the pump
WCVH6260HWW GE front load washer won't start - press the On button, then press Start/Pasue button and it goes beep beep, and keeps blinking, and washer does not start; the washer pump strainer has been...
no power to control panel checked outlet with another appliance it worked drained water from pump filter still nothing door locked and nothing on control panel
6helpful
2answers
Front loading ge washer won't drain?
Similar problem fixed in less than 5 minutes. Here's a post that was very helpful. http://www.foobert.com/blog/2007/04/02/ge-adora-front-loading-washer-does-not-drain/
There's a trap located under the front panel (3 screws) I undid the filter and pulled out 21 coins, 2 buttons, a 'letter h', zipper parts, a broach, and a whole lot of lint.
My wife said that the unit never got the clothes so dry afterwords, she said the almost didnt need to throw the clothes in the dryer.
NOTE: Have a ton of towels ready, and if you can fit a bucket or dish under the filter, go slow and steady. I opened it up and had several gallons all over the floor!
6helpful
Clogged washer pump
you have to take out the little motor that drains the water and clean it up , first you open the front panel or back panel depending of the model , second follow the DRAIN HOSE to where its attached to the DRAIN MOTOR , remove the motor for cleaning , its probably clogged.
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
