Question about Uniden DECT 6.0 Cordless Phone ID
Record outgoing message
How to record outgoing message
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you declined to specify the model of your Uniden DECT 6.0 system I can only suggest that you select it from the list beginning here to download a copy of the manual.
Posted on May 01, 2012
4 Suggested Answers
SOURCE:
  • 102366 Answers
SOURCE: Need to record Outgoing Message for Vtech 5.8 GHz
http://www.vtechphones.com/vtechui/support/manual_list.cfm
Posted on Jul 19, 2010
  • 3 Answers
SOURCE: Philips Dect 521 / 525 help need to record a new outgoing message
here is the link for the user manual for the 2151
Posted on Jan 14, 2009
  • 214 Answers
SOURCE: I can't remember how to record my outgoing message ?
here you go...
Recording your greeting
message
You can record your own greeting
message (max. 2 minutes and 30
seconds). If you do not record a
greeting message, a prerecorded
greeting message is used.
1 {MENU}
2 {V}/{^}: “Answering devicei
{OK}
3 {V}/{^}: “Record greetingi
{OK}
4 After the handset beeps, speak
clearly about 20 cm (8 inches) away
from the microphone.
5 To stop recording, press {OK}.
6 {OFF}
If this helps you solve it, plz rate this fixya. Thank you kindly.
Posted on Feb 01, 2009
How do I record a message outgoing?
Since you declined to specify the model of your Uniden system, I can only direct you to select it from the list here to download a copy of the manual.
Dec 19, 2011 | Uniden Lands Phones
I have recorded an outgoing message. However, at the end of the new outgoing message an old obsolete outgoing message starts to play. How do I get rid of the old outgoing message?
You will need to remove the old message. There SHOULD be prompts. IF NOT try going to a very quiet room and hit record but do not say or make noise and this will record silence over the old and new message. Then attempt to retry.
ALSO - look for a 'reset' button and remove all batteries if you have power outage back up batteries.
Unplug the phone - and try again.
Here are the instructions from the manual:
To Change Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
Best of it
Gary @ Fix Ya
Jul 20, 2011 | NorStar M7324 Telephone
How do i get messages from remote location
To use your system from a remote telephone, you must first enter a 3-digit remote operation security code. The security code label is located on the bottom of the system.
1. Dial your phone number.
2. When your outgoing message is playing, enter your remote operation security code. Bd appears on the display to indicate the system is in remote mode.
If there are no new messages, you hear three beeps.
These are the remote codes available to you:
2 # Play all messages.
2 5 Play new messages.
3 # Delete all old messages.
7 # Record new outgoing message.
7 # Stop recording outgoing message.
8 # Record memo.
8 # Stop recording memo.
9 # Turn system off/on.
0 # Monitor the room..
Jun 12, 2011 | Radio Shack 3822 Digital Answering Machine
How do i record my own message
Recording Outgoing Messages:
1. Hold the ANNC-DAYand speak clearly into the microphone.
2. Release the ANNC-DAY when you finish. Your answering machine beeps and automatically plays back your recorded message.
Message limit:
60 seconds
To re-activate pre-recorded message:
Press "delete" during while playing your outgoing message. The pre-recorded message is now activated.
Feb 21, 2011 | Radio Shack (43-3829) Digital Answering...
How to record an outgoing message on Radio Shack answering machine, cat. no. 43-3825, serial number 40318384.
Hi, to record an outgoing message:
- Press and hold the ANNC/DAY/<< button. - While you're holding it down, say your outgoing message. - Let go of the ANNC/DAY/<< button to end the recording when you're done.
Your message can be up to 1 minute long.
Nov 28, 2010 | Radio Shack 3822 Digital Answering Machine
Jul 03, 2010 | Vtech 5.8GHz Cordless Phone with Digital...
How to record Outgoing Message on Answer machine of BINATONE FUSION 2210 DECT phone? Thanks
hi,
if you want to record outgoing message on Answer of BINATONE FUSION 2210 DECT phone, his the step you will follow.
to turn A/M on press R then 5.
to turn A/M off press R then 6.
if you want to record Outgoing Message, press R then 1.
After beep record your message.
Press 0 when you have finished your message, then C to return to standby mode.
To listen to incoming messages, press R then 8.
New messages are then played back.
Press 4 to delete message.
thanks for using fixya
Jun 05, 2010 | Lands Phones
Cannot acess option to record outgoing message need to get to option 8 to record message
All phone is no recoed outgoing ok than you can incoming call to record tha message
Oct 05, 2009 | Uniden 5.8GHz Dual Cordless Phone
Nseed to reset message on answering machine
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Thanks
Len
Mar 07, 2009 | Uniden TRU8885 Digital Answering Machine
Radio shack 43-3829 answering machine
Well, your machine might be broken, or you haven't set the little switch on the unit to ANS. The switch is on the side of the machine where the cables come out. But here are the instructions from the manual:
Your answering machine has a built-in outgoing message, "Hello, please leave a message after the tone." You can use this message or record your own.
1. Hold the ANNC/DAY/<<, and speak clearly into the microphone, no more than 10 inches away.
2. Release the ANNC/DAY/<< when you finish. Your answering machine beeps and automatically plays back your recorded message.
*Your outgoing message must be between one and 60 seconds.
*If you record your won message but wish to revert to the pre-recorded message, press DELETE during playback of your outgoing message.
Nov 09, 2008 | Radio Shack 3825 Answering Machine
Uniden DECT 6.0 Cordless Phone ID Logo
142 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
