Small floor safe Sentry Model 3877 electronic lock and key
How long does the battery last for the electronic lock and how would you open the safe if the battery died? We have had the safe for four years and have not changed the battery.
Lost the mannual & need to change the battery for the combination. Need directions to change the battery.Lost the mannual & need to change the battery for the combination. Need directions to change the battery.
AnonymousMar 13, 2014
Bighorn Classic, 30 gun electronic; battery reads 9.21 volts, all paperwork locked in safe; cannot open safe; can I get factory number to open safe?Bighorn Classic, 30 gun electronic; battery reads 9.21 volts, all paperwork locked in safe; cannot open safe; can I get factory number to open safe?
I have a ten year old safe . its a electronic and key steele safe . I have serial no.M325860 and factory code 32298 which i have lost the key to how do i get a new key thank you for your helpI have a ten year old safe . its a electronic and key steele safe . I have serial no.M325860 and factory code 32298 which i have lost the key to how do i get a new key thank you for your help
AnonymousMar 23, 2014
I bought a sentry safe and I want to change the combinationI bought a sentry safe and I want to change the combination
AnonymousMar 26, 2014
It's locked and I can't get in it, it small cash fire proof boxIt's locked and I can't get in it, it small cash fire proof box
AnonymousMar 29, 2014
sentry safesentry safe
You can't post conmments that contain an email address.
Locksmiths agree try replacing the batteries just slide open the battery cover located just below the keypad. Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated. reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Locksmith advice on how to install sentry safe batteries slide open the battery cover located just below the keypad. Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated. reconnect the connector and put back the battery holder. Slide the cover back in place.
Sounds like the batteries are dead.
How to install sentry safe batteries slide open the battery cover located just below the keypad. Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated. reconnect the connector and put back the battery holder. Slide the cover back in place.
Locksmiths agree on how to install sentry safe batteries slide open the battery cover located just below the keypad. Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated. reconnect the connector and put back the battery holder. Slide the cover back in place.
Locksmiths say this is how to install sentry safe batteries slide open the battery cover located just below the keypad. Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated. reconnect the connector and put back the battery holder. Slide the cover back in place.
To install sentry fireproof safe battery slide open the battery cover located just below the keypad. Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated. reconnect the connector and put back the sentry safe battery holder. Slide the cover back in place.
Locksmiths install sentry safe batteries this way slide open the battery cover located just below the keypad. Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the sentry safe battery holder Insert the 4-batteries as indicated. reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safesmy locksmith recommended me To install batteries,
Sentry Home Safes battery location slide open the battery cover located just below the keypad. Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated. reconnect the connector and put back the battery holder. Slide the cover back in place.
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, next replace the electronic lock case and turn to the left to reassemble.
sentry safe
