JVC GR-D850 Mini DV Camcorder Logo
Posted on Feb 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camcorder not charging
I have a jvc grd820 camcorder.
not used for 2 months.
tried charging, left on overnight, but battery totally flat.
camcorder works ok when connected direct to mains.
any help appreciated
Anonymous
Level 3:
  • Master 583 Answers
  • Posted on Feb 06, 2010
Anonymous
Master
Level 3:
Answers
583
Questions
0
Helped
226790
Points
1903
Since the camcorder will power up and work with the charger connected, it sounds like the battery has died and will no longer hold a charge.
My car battery is totally and completely dead on my G5 2008 Pontiac as the lights were left on overnight. There were zero indications or problems before. I tried to charge using cables and it was totally...
Have your battery tested / charged.
Totally dead battery may take some extra time to charge being hooked to cables.
When a battery is "hard discharged" as you described...sometimes they never recover and require replacement.
Sir, I have a JVC camcorder GR-D53 & the Battery has become flat & cannot be charged. Where i can get a new battery. Please help me. Oswald
try JVC website and search for your product and see if they still make the accessories as I don't know how old your product is.... on the left side you can find links that may help also: http://www.jvcservice.com/service/JMdlPrtXrf.asp
Jan 04, 2011 • JVC Cameras
2answers
DCR-TRV30 Internal clock battery is end of life. It will not charge overnight or hold date/time set information between main battery changes. There is no replacement information in the user manual. Where...
This small back-up battery on my Sony is under the main big power battery, it is like a large screw under the main power pack, I just turn that screw and the little round lid comes off to get to the little silver flat back-up one.
They are readily available from most good camera shops like Jesops for around £12 to £15 each.
Battery not charging
could be that BATTERY lost its capacity to store energy , or check the contacts make sure there clean , use a Q tip and alcohol , hope it helps , AJ
3answers
My Aiptek keeps coming on then shutting off! It's brand new, I've tried taking the battery out but it still does the same thing
Mine does this if the battery is not charged. Make sure the battery is installed with the contacts lined up (my daughter is a pro at putting the battery in upside down, and it doesn't connect to anything that way!) and charge it up overnight.
If it's still giving you trouble the next day, post back and we'll try something else.
8helpful
Jvc gr dvl520u - won't turn on or charge
Take out the battery and clean the gold connectors. I had the same problem for months and finally I tried this and it worked perfectly afterward.
Download
recently bought a used jvc camcorder gr-d290 but even when l pu tthe battery on charge for hours it goes flat in less than twenty minutes . what can be the problem?
JVC GR-D33U Doesnt charge
your battery way have went bad shorted internally.
if this is what happen and you pluged the charger in it may have also shorted out your charger.To know for sure get a good battery and test the camcorder,you may need to get a new or recondition charger.hope this has help jerry
1helpful
Error flash on screen
How long have you had your camcorder?
This is my history about using camcorder,
I bought 3 Sony camcorders at different times, I have used not more than 20 times for each, and my brother bought another kind of camcorder did the same, but after 3-4 years, automatically quit one by one, even my brother’s camcorder quit within 4 years too, this is what I think, the big companies like Sony, Jvc etc., won’t let you use the same unit for a long time, from our case, made us thought, they probably put a timer to control the age of the camcorders. Maybe we have to know how to adjust or change the timer chap, this called a quality control.
I am still research about this case. And also I have a lot of documents can not transfer.
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
