Question about Bosch Washing Machines
Front Loader Washer Door Hinge broken
The cast aluminium hinge for the door on my bosch maxx 800 front load washing machine has snapped. Where on line can I buy a replacement part?
  • Ji?w?n G?ngc?
    Ji?w?n G?ngc? Nov 16, 2012
    I am looking for this product # 134412400 ( Frigidare front load washer door Hinge's)
  • Bosch Master
  • 3,463 Answers
There are a couple of sites you can try.
WWW.ESPARES.CO.UK/BOSCH
WWW.4BOSCH.CO.UK/SPARES
Please rate my solution.
Thankyou
Posted on Feb 06, 2010
6ya staff
SOURCE:
How to change the door hinge
Link to PART:
Bosch Washer Hinge - AppliancePartsPros.com
http://www.appliancepartspros.com/bosch-washer-hinge.html
Link to VIDEO - "HOW TO REPLACE DOOR HINGE"
(scroll down half way at this link)
VIDEO: Washing Machine Door Hinge ' eSpares
http://www.espares.co.uk/product/es486275/washing-machine-door-hinge
Jul 09, 2014 | Bosch WFMC 2100 Front Load Washer
My frigidaire washing machine door hinge snapped
Hello - Contact the manufacturer to see if they have any updated or alternate door hinges that you can install yourself. The weight of some front loader doors, and how they are closed/slammed, can wear over time.
Nov 03, 2012 | Frigidaire ATF6000ES Front Load Washer
How do I replace the door seal to a Bosch Front loader washer Maxx Classic WAE18060AU?
To change the seal the easiest way is to take the front of the appliance off. Remove the kick plate at bottom and you will see some screws holding the front panel on remove these Then open door and remove the screws holding the door lock on and unlip the seal by releasing the clamp on the front. The front should now lift off, if it doesnt then pull out the soap drawer and behind that at the bottom of the drawer is a screw holding the front on remove this then push the front panel down then it will lift off You can now take the clamp holding the seal to the tub off. Fit the new seal, fit the clamp to the seal and tub. From here, rebuilding is the reverse of the strip down.
Feb 18, 2010 | Bosch Classixx WFO 2466 Front Load Washer
The hinge of the washing machine has broken - Creda W100FW
The door hinge block has fallen inside the front of the washer.To retieve it, tilt the washer back, and you should find it at the left hand side.
Remove all screws securing 2 parts of door together, prise apart with a screwdriver or similar, and the door will come apart.
You can now access the hinge and all other partsd inside the door.
Trust this helps.
Thankyou.
Nov 28, 2009 | Creda W100FW Front Load Washer
Door broken at hinge area on Maytag front load washer 24".
Try using some J.B. Weld on it instead of glue. It will essential form a weld and should hold up better. You might want to give that a try. Good luck and best wishes.
Aug 04, 2009 | Maytag MAH2400 High Efficiency Front Load...
Door hinge is broke on Bosch Axxis+ Front loader
There are 4 screws in the door that hold a plastic hinge cover on
.The door will then set into the hinge just fine (PLENTY OF ROOM) and then you put the hinge cover back on and screw the screws in to hold the door onto the hinge.You will likely need a 2nd set of hands to keep from breaking the door.
Oct 10, 2017 | Bosch Axxis WFL 2060 Front Load Washer
Bosch 500 series Front Load Washer Door hanging a bit lower than when purchased
Even if you do not realise it most people lean on the door as they open it, to rectify with the door open but almost in the closed position lift the door by pulling up on the door catch end, this will straiten the hinge, very common problem Regards Engineer
Jul 26, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
462 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
