Mitsubishi WS-55807 TV Logo
Posted on Feb 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi WS-55807 TV won't turn on
I was watching my Mitsubishi WS-55807 tonight and suddenly a loud pop from the speakers as the tv shut off on its own. Tried to turn it back on - green light came on for a few seconds then went off. No picture or sound. Started smelling burnt circuitry. Removed back cover but didn't see anything burning or burned. Help????
Thanks,
Shawn
Castle Rock, CO
  • 2 more comments
  • blondilox Apr 27, 2008
    i have the same tv and the exact same thing happened. what did you find out? i can't decide to spend the money to fix it or just buy a new tv. thanks so much
  • Stanley151 Jun 16, 2008
    The TV used to make this loud pop then shut itself off. I would turn the TV back on, it would pop then shutoff after a few times it would eventually stay on. Last week it did it again but this time it would not come back on. I have sound but no picture.
    Any suggestions?
  • Anonymous Oct 15, 2008
    I have the same problem with my big screen. I was told (and saw with my own eyes) that it was the "Signal Board". It had a large scorch mark in the middle of the board. The tech said that it is usually caused by one of the "color tubes" leakig acidic fluid from above onto the circuit board and causing it to carrode the board and short out. But, I had no sign of any of the color tubs leaking so he concluded that there was a possible electrical surge. My issue is that we can not fine a new or used "Signal Board". Any suggestions???
  • Anonymous Feb 21, 2009
    i have the same problem, tv was working fine day before now the green timer lights blinks then shut off- was told that it was the powerboard will look into further and post it but a free download of the user manual is avail at: http://www.opweb.de/model.php?id=2693 just download at no cost.
Anonymous
Level 3:
Genius:
  • Master 1,665 Answers
  • Posted on Mar 23, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1665
Questions
Helped
979446
Points
3981
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service ManualMitsubishi WS-55807 TV won't turn on - lockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Feb 28, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
3807
Points
Did you find anything else about it
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 01, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
2404
Points
I have the same problam,I got this tv for free and i am trying to find out what is wrong with is so i can fix it.has any of yall got yalls fix if so what did you do to get it to work.
Thanks
Dustin
Mitsubishi ws-55807 wont turn on and has no standby light
Its SMPS switching regulator section is faulty. Troubleshooting this section is a skilled work. Contact any experienced service technician.
My mitsubishi big screen projection tv, 1080, all of a sudden turned off. When I turn it on, it automatically shuts back off. I did the reset test and it blinks 2 times, blinks 2 times and a pause. How...
you have a bad or leaky capacitor in the power supply section...if you can dismantle the back casing look for the power supply and check if there's a bulgy capacitor mostly electrolytic type....replace w/ same value..it's best if you brought it in a tv service center
6helpful
3answers
I turn on the tv and it shuts off after a couple seconds
if you unlpug your tv and plug back is the green ligth blinks for one minute?
let me know so i csn help you
Mitsubishi WS-55807 Horizontal line in screen, no sound
it sounds like you may have a faulty frame chip. but could be capacitor. who knows for shure, exept an engineer?!?!?
Close captioning stays on all the time.
if have remote or tv bo to menu scann threw it find captions and set off this may help
Won't come on
The power board has failed and will need to be repaired or replaced. you can remove this board and, replace individual parts and save a lot of money. You will be inspecting for swollen capacitors and resistors. also, look for discolorations on the board itself.
1helpful
2answers
My mitsubishi 1080 WS-55807 has lost the picture
Unplug the set, remove all other audio/video components, go open front door, and roll it out to the curb.
Mitsubishi ws55807
does the menu show up?
TV won' turn on
Solder, solder, solder! Shut down circuits protect crts to avoid permanent damage. If any of the deflection circuits are defective, or intermittent, shut down occurs. I have not only seen bad solder on deflection circuits, especially vertical, but also intermittent connections on the yokes themselves. I've also seen shorted convergence ics cause shut down. Don't forget solder connections in the power supply.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
