Coleman 10' X 10' Sundome Tent 9160K101 Logo
Anonymous Posted on Feb 06, 2010
What is the stretchy cord holding your tent poles together called, and where can you purchase some?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 204 Answers
  • Posted on Feb 06, 2010
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
204
Questions
Helped
71620
Points
505
Slang term is bungie cords, but its just better and cheaper to buy new poles than deal with a pain in the @#$!
Testimonial: "Thanks but I really want to fix them "
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
126
Points
It's a shock cord, you can buy them at EMS, pretty cheap and really easy to replace.
Ozark trail tent wmp1711 poles
There are a few places you can look for replacement poles for your Ozark Trail WMP1711 tent.
1. Manufacturer's Website: Checkthe manufacturer's website for replacement parts or contact their customer service department to inquire about replacement poles for your specific model of tent.
2. Outdoor Retailers: Visit outdoor retailers that carry Ozark Trail products, such as Walmart or Academy Sports + OutOutdoors. They may have replacement poles available for purchase online or in-store.
3. Online Marketplaces: Check online marketplaces such as Amazon, eBay, or Craigslist. Sometimes you can find individual sellers who are selling replacement tent poles for various models. Make sure to confirm that the poles are compatible with your specific tent model before making a purchase.
4. Tent Repair Services: If you're having trouble finding replacement poles, consider reaching out to tent repair services. These professionals may be able to create custom replacement poles or suggest alternatives that would work for your tent.
Remember to provide specific details about your tent model, such as dimensions or specifications, when searching for replacement poles to ensure they are compatible with your tent.
2answers
Swiss gear tent 36288 manuals
How to set up swiss gear tent model 36288
1helpful
Disney car tent assemble
I couldn't find the instructional manual, but I did find this image from another answer on FixYa that may be helpful: http://www.fixya.com/support/t9852139-assembly_instructions_disney_princess
Most dome tents are assembled by feeding the rounded (or bendable) poles through loops on the inside of the tent cover. Small connectors and joints should be included to put the poles together into the shape below. Good Luck!
5helpful
I purchased the toy story bed tent for my daughter and misplaced the instructions on how to put it together so if you could provide me with this I would really appreciate it
there are four pockets on the inside of the tent which hold the ends of the pole with the string in them. connect all the poles with the string in them. bend it in a (n) shape and stick the ends in the pockets. the poles are bent so as to give the tent height not depth, do the same for the rear of the tent. the twelve other poles are connected using the small connectors. one connector for two poles then stick those poles into the front and rear (n) shaped poles in the empty connector spaces already on the pole you bent. remember when you bend the pole they will not stay bent until you stick them into the inside pockets in the tent. the nylon straps at the bottom of the tent help the tent to hold on to the mattress. its simple enjoy. i put all the poles together first and then had my helper to hold it in a (n) shape until i could stick the legs into the pockets. look inside the tent once together you will see where you need to tie the nylon straps to the poles
29helpful
2answers
Hello. I have a disney princess bed tent that my daughter recieved for christmas. We went to go and set it up and the instructions are missing. Is it possible to get a copy faxed/emailed to me?
I just put one of these up today with no instructions so I am going to share my experience. In my Disney bed tent there were two long sets of poles held together by an elastic string. 1) put these two sets of poles together. Now you should have two long poles. 2) Turn the three way brackets all the same direction on both long poles. 3) Lay out the tent and look in each corner of the tent for a little pocket to insert the end of a long pole...taking the other end insert into pocket, not diagonally, straight across the long way. 4) Do the same with the other side of the tent and long pole. 5) Now take your ten short poles and attach two together making 5 medium sized poles 6) Push these into the brackets along the long pole, kind of has a ladder effect. You are done!! I use mine with a full size blow up bed, the elastic gets stretched but I can set it up easily outside, or in the livingroom. Enjoy Nancy
May 19, 2010 • Toys
2helpful
The elastic cord of the tube poles of the rainfly of my camping tent broke. The ends have a hard rubber or plastic cover that seems to be permanently attached. How can I remove them so I can replace the...
Those stretchy tent poles are at walmart, real cheap, Buy a couple and you will have a spare. If you want to fix the old one, I would try a couple solvents to loosen the glue, then remove the tip. Goo gone, or one of those to start, then move up to the mineral spirits, then the laquer thinner, If that doesn't do it, Nothing this side of fire will do it. Laq thinner is the strongest solvent available. Be carefull.
Centre pole is failing to hold tent up in any real wind
TRY DRILLING A SMALL HOLE ON THE INNER POLE SLIGHTLY SMALLER THAN THE DIAMETER OF THE SCREW. U WILL WANT TO DRILL SMALL HOELS EVERY FEW INCHES(CM) SO THAT U WILL BE ABLE TO SET THE POLE AT VARIOUS HEIGHTS IN THE FUTURE.
4helpful
2answers
I have a greatland tent item #15710. This is a two room tent (not dome) with a screened porch. The poles have numbers and some numbers are blue and some red. I cannot identify whether the numbers go in...
I am looking for a manual for Greatland Outdoors 2 room tent with screen porch item #15710, however, I guessed how the poles go together. I set up the tent by myself, but I recommend 2 people or more, especially if it is windy.
Start by stretching out the bottom of the tent into a square, and stake all of the perimeter tentloops to the ground, starting with the corners, with the stakes directed at a 30 to 45 degree angle under the tent, so the tent cannot easily pull them back out. Leave the yellow cords attached to the tentloops loose, so you can use the cords to help pull up the stakes when you take down the tent.
Now assemble the poles going through the loops across the front of the screen porch. Insert one end of a pole #1 into a pole #2 and thread them through the loops over the entrance to the screen porch. Put the long end of a curved pole #3 through the loops starting from one side, and attach to either side of the 1/#2 you made. Put the long end of another #3 through the loops starting from the other side and attach to the loose end of the #1/#2. You should tie the loose green cords on each corner of the sceen porch to the silver metal rings at the curved end of each #3.
Later, you will do the exact same assembly with a #3 on each side of a #1/#2 for the poles going across the back of the tent and the poles going through the pocket across the middle/top of the tent.
Now insert the small end of pole #4 into the curved end of a #3, then insert the small end of a #5 into the open end of the #4. There should be a rubber foot on the bottom of the #5 pole. Do the same thing for the other side of the porch. With help, you should be able to prop up the front of the sceen porch, pulling aganst the stakes holding the rear floor of the tent, and place the rubber feet of the #5 poles close to the center loops of the floor on each side.
Now prepare the #1/#2 poles for the rear, and attach a #3 to each side and tie the loose green cords to the silver rings on the short ends of the #3s. Prepare a #4/#5 pole the same as the front, and prop up the back of the tent, putting the feet near the side loops of the floor which are about 1/3 from the rear of the tent.
Make another #1/#2/#3, and push it through the pocket across the middle of the tent, and connect the last #3 from the other side. The side supports for the middle are pole #8 with the white clamp on the bottom, and pole #7 slid into pole #8 (The #7 was scraped off both of mine). Leave the #7 mostly inserted into the #8 until after the center is lifted up. The #6 goes on top of #7, and insert the #6 into the curved end of the #3 poles which are already in the center pocket, and tie the loose green cords to the silver rings at the short end on each of the #3s. Now lift up the center with someone helping on the other side, and put the feet of the #8 into or near the yellow loops at the center of each side. Loosen the white clamps and extend the #7 poles until the peak of the tent is at proper height.
Move the feet of the #5 poles closer to the tent, until all is tight, and you should be done!
1helpful
No instructions on how to set up 3-bedroom Coleman tent.
First, I would try Coleman.com and see if they can send you a manual or direct you on their website.
Assuming the picture is the tent I can help (and even if it isn't, these are basic setup steps). Peg the tent down. Lay it out and pick about six spots to peg it down.
Next, get the two or three longest poles. These are the support poles. Run them diagonally or maybe side to side through the pole sleeves on the top of the tent. Once all the way through, put one end in the hole (or possibly in the pin) depending on if you poles have points or holes in the end. You'll then bend the pole, raising a portion of the tent to make the other end of the pole fit. Look for hooks to hold the tent poles to the poles. Do the same for the other pole/s. And it doesn't matter which pole goes together first.
Once you have the two or three longest ones in, the rest is extra. From the looks of it, you may have one pole running from the door area to the rear. If there is one, it's usually slid into a pouch and tied with a plastic string at the top of the tent to the other poles.
Other poles, if they are there are for side support or rain cover support.
Figure out which way the rain cover goes, then attach the bungie to the pole at the base of the pole. It should have some type of hook. Once the cover is on, it may take a pole underneath it. If so, there will be a small pocket or pouch for the pole.
Don't worry about the strings and extra stuff. (Unless you're expecting monster winds). You should have extra pegs, strings and maybe a pole or two. As long as you get the main two or three support poles up, you're solid. Good luck
Top Coleman Sport & Outdoor - Others Experts
Kardoc
vince
john h
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
