TitanNet TITANTANKLESS. COM PRESENTS THE TITAN SCR2 WHOLE HOUSE TANKLESS WATER HEATE Logo
Anonymous Posted on Feb 05, 2010
When turn on the hot water only the top red and green lights are on and the water is not hot
Sean Wright
Level 3:
  • Master 2,045 Answers
  • Posted on Feb 06, 2010
Sean Wright
Master
Level 3:
Answers
2045
Questions
Helped
627210
Points
6368
Is it wired correctly..check all your wiring
if its a new install call the place of purchase or the manufacturer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Titan n120, green light and red lights are on , water doesn’t get hot , ???
While it could be many things that have gone wrong, the most likely cause is the heating element has failed. Call the local dealer.
Rheem rte13 standby (green) light not on
You might have crossover problem caused by bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
The green standby light should come on when 240Volt power is applied. Page 6 manual.
Both red lights should come on when tankless is activated. Page 6 manual
RTE 13 requires 60 amp breaker and 6 gauge wire
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
http://waterheatertimer.org/pdf/Rheem-TanklessElectricUC_AP15447.pdf
Factory temperature setting is usually default 120 degrees.
Adjust temps page 11 manual
Thermostat calibration is always approximate.
120 degrees is not hot enough to burn the skin.
Exceptionally cold incoming water temperature can cause tankless not to heat enough hot water: install tempering tank to preheat water to room temperature.
Tankless cannot be exposed to more than 11 grains hardness in water. Delime tankless yearly, clean water filter monthly, do not install low-flow restrictions or conserve water since the flow rate must remain high for tankless to activate.
Rheem does not post service manuals for their tankless water heaters.
Call Rheem 800 432-8373
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Pilot light on hot water heater is out
you need to shut off the the red nob and turn the nob off in front take the cover off remove the heat shield turn the nob on top to pilot use a piece of paper to light put in next to pilot and hold button down for 20 to 50 secs pilot should stay lit turn nob on front then burner should kick on then you should be all good
2answers
No hot water, control board light stays green
It may be bad thermostat terminals of the water heater, or, alternatively, the very top heating element is in need of replacement. See this handy diagnostic article for more info:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Heating_Systems_Water_Heaters_Cold_Water_Still_Released_Despite_Water_Heater.htm
Hope this helps.
Brad
Top TitanNet Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a TitanNet Water Heater Expert? Answer questions, earn points and help others
