When using the ADF to scan multiple document the scanner assembly stay stationary and the paper is fed across it. Where the scanner parks for this there is something between the scanner and the document, likely on the glass. Often there is a small strip of glass on one end of the scanner bed. Clean here if there is one, otherwise look around and I'm sure you'll find it. Remember, never spray cleaning solutions directly onto the glass, always onto a cloth or towel first. The scanner has a calibration strip that can be damaged otherwise.
Important
The inner side of the Document Cover (white sheet) (C) is easily damaged, so wipe it gently.
If the glass of the ADF (A)
is stained with ink, correction fluid, or the like, black streaks may
appear on the printed paper when the document is loaded in the ADF. With
a clean, soft, lint-free cloth, wipe the glass of the ADF.
With a clean, soft, lint-free cloth, wipe the Platen Glass (D), the inner side of the Document Cover (white sheet) (C), the glass of the ADF (A), and the inner side of the ADF (white area) (B) gently. Make sure not to leave any residue, especially on the Platen Glass.
Cleaning the ADF
Caution
Be sure to turn off the power and disconnect the power cord before cleaning the machine.
1. Open the Document Tray.
2. Open the Feeder Cover.
3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Feeder Cover (A).
4. After wiping, close the Feeder Cover by pushing it until it clicks into place.
5. Close the Document Tray.
6. Reconnect the power cord then turn on the machine.
