I am having a problem with my Samsung YP-T10 mp3 player. Ive been trying to update the software but I just don't know how. I really need someone's help. Ive downloaded the software but after that, I don't know what to do.I have the Samsung media studio which should update it automatically but when I connected my mp3 player, it said if I wanted to update it. I selected to update the firmware but I didn't see any difference. It had the same blue tooth menu(nothing had changed). Please reply as soon as possible. I will be very happy if you do so. That's all for now. Tank you.
This drove me crazy, too! The trick is that you have to search the download section of Samsung.com with your very specific model number. You can't just use T10 or T10JAW just because that's the example they used on the website. For example, mine was YP-T10JAUY. Save the zip file to your desktop, then extract the files to your desktop (doesn't matter what folder name as long as you remember where the file are). Next, open a Windows Explorer window by right-clicking the "Start" button and select "Explore". Obviously, your T10 should be connected already. You'll see the T10 on the left-side window. HERE'S THE REAL TRICK: you have to get the T10 files to show up in the RIGHT side window. Click on the T10 to expand the internal folders (still in the left side window), then in the left window click on either "Data" or "Internal Storage"--which one you see will depend on whether you use Windows Media Player 10 or 11. Click on that on the left side and it should open the right side Explorer window to the files in the Data or Internal Storage folder. This is where you have to put the firmware. On the right side.
You can't drag-drop the firmware update files into the T10 in the left-side window. This is NOT clear in the firmware update instructions that you see in the new manual that goes with the new firmware. After you copy the firmware to the T10, you just disconnect from the computer and when you turn it on, it should upgrade the firmware.
Those YouTube "how to upgrade firmware" videos don't describe this...a HUGE oversight. None of the other various supposed how-to explanations said this stuff either. JEEZ! It's not that hard if someone would just explain it correctly! I wasted HOURS trying to figure this out. I hope it helps you.
jkronk
When i plug in my samsung T-20 mp3player the icon doesn't come up and when i click on "my computer" it does not show that i have plugged in any device what should i do?
HEY ! I have a T10 of full model # :- Samsung T10JAUY.Then I downloaded the new firmware from www.samsung.com.The file I downloaded was T10A.Does my model supports the file og T10A>if not which file should I download?
HEY Â HEY Â HEY Â HEY Â HEY Â HEY Â HEY Â HEY Â HEY
I have downloaded the files needed to update the T-10JAUY(mine one)...OK..then I have copied it into nternal storage..Then when i switch on after disconnecting.. does not start automatically..whats the F**KING problem yaar...PLZ ANYONE TELL ME>>>>OR post to "[email protected]"...plzÂ
I apparently just had to update my mediaplayer!!solves al this **** of not finding your t10 in explorer...
Pllzzz help me i cant upgrade my firmware
i loose also d installation cd
where do i find another??
What? that's basic use of windows. If you can't do that you should use a mac. c'mon!
You can also download the firmware upgrade from the samsung website, which is way easier than looking for it on emodio
just go to samsung.com >> experience >> downloads >> search for your device >> click on it >> firmware upgrade
and you go on from there to download it into your player
What you do is just go to the root directory and drag n' drop the files there
My headphones got damaged and any time i insert other headphones it doesn't work
There is special software to use when doing the firmware upgrade which is "FWDN"(Firmware Downloade telechips.) and "VTCDRV"(driver) this one is only for service tech use.It will do firmware upgrade (T10.ROM & T10.rsc).This one is for T10 & S5
Hello
i had problems with my t10 everytym i turned it on it turned bak off...so someone told me 2 download the firmwave so i did be wen i copied n tried 2 paste it in my internal storage it couldnt paste..can someone help me plzzzzzzz..!! thank u..
Hey hey i use emodio its better
SOURCE: Firmware Upgrade for my YP-T10
is on the white stiker it will say t10 jaby or somtin els and yea there firm ware on the site and games when you get that uprade
SOURCE: samsung media studio??
You have to update the driver of you player.
Click on START menu and RUN.
Type in devmgmt.msc and click ENTER.
Now you Device Manager will pop up. Look for your player under Other Devices or Portable Devices
Once you find it, right click on it and select Update Driver (make sure the installer disc is in your CD drive).
It should work fine after that.
when i plug in my samsung T-20 mp3player the icon doesn't come up and when i click on "my computer" it does not show that i have plugged in any device what should i do?
where to download samsungT10 firmware?If u know show me more
Thanks
i have used the disk proved and it wont show my mp3 i have tryed up dating the software and the firewall but still wont read my mp3 player . the media studio plays my music but dont see my mp3
after I downloaded the upgrade when I turned on my T10 it says to please upgrade RSC file and I cant do anything
Fantastic instructions... THANK YOU...
However, I don't seem to have a file called 'data' and the file called Ãnternal storage' seems to be locked and I can't copy/drop any files here.
I do have a folder called 'system' which is where I've put the update files, however it doesn't seem to have done anything.
Anyone else come across this?
My mp3 samsung keeps telling me to uprage the RSC file???? what is that???? i opened my program and i did wat it told em to do and it didnt do anything and now its aksing me to uprage RSC file on the actual mp3 player and won't let me listen to anything. HOW DO I UPRAGE THE RSC FILE?????? please let me know soon!
thank u
Same thing...upgrade RSC File
i want to get the menu styles games and all other updates
I follow the instruction according to what to how irunamok had taught but it still doesnt work for mii :( someone pls help mii ?
kindly email mii @ [email protected]
much appreciated !!!!
i followed e exact details and the fireware suddenly had a problem asking me to upgrade my rsc file.wat is the problem?i am also unable to find the data or internal storage file as mentioned.pls help
Every time I turn on my Mp3 It says Please upgradeRSC file what should I do?
I did everything, even what that guy told me to do, and what the website told me to do. Nothing worked.
I am getting Upgrade rsc file when i turn on my samsung yp-t10 player. I tried reset, formatting the drive but it did not help. Please help !
hi this is omkar here..the software has not been updated even after doing the needful...the bluetooth doesnt work at all as in the data which is received is lost after connecting it to the comp..pls help me
I downloaded the appropriate zip file from Samsung.com to my desktop and extracted two files:t10.rom and t10.rsc ; but could only copy t10.rom to my Samsung YP-T10QB because the second files requires too much memory. Now what?
My Mp3 player is telling me to upgrade rsc file. I tried everything and it is'nt working!
I bought a samsung t10 and by mistake I lost the cd. How can i found t10's driver
My T-10 Model # is non existing? I am so confused!!!
My samsung YP-T10 8gb keeps freezin on me when i push reset i can only play 1 playlist And it is soooo slow :(
Heather.
uguale!!!
yo some one help me my samsung t10 cant get the new firmware someone help me
power on not working when usb connect RTC checking coming on the disply
