Nikon D70s Digital Camera Logo
Posted on Feb 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My nikon d70 says that file does not contain image data
Anonymous
Level 2:
New Friend:
  • Expert 63 Answers
  • Posted on May 13, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
63
Questions
0
Helped
16971
Points
140
If the memory card came from a different camera and inserted into the Nikon D70, the error message will appear. Just format the memory card with the D70 and the error should disappear.
Hope this helps.
Andrew
Nikon coolpix s4300 keeps saying file contains no image data
Call Nikon they can fix it they ask you to send it to them and they tekk you how much you send it and they fix and mail it back it shouldnt cost that much nothing is broke.
1helpful
DISK SAYS "FILE DOES NOT CONTAIN IMAGE DATA" BUT
hi there,
this case will happen if you still have pictures on memory card and it hasn`t been formatted using the Nikon system
the solution is backup your files on memory card to PC/laptop, then reformat the memory card using Nikon menu
hope this will help you
I have a Compact Flash card of 512mb (CF card) i use this card in my nikon D70, i went to my friend house and tried connection my camera to his comp to download image, but my friend machine was infected by...
Guide to recover deleted photos from Nikon D70?
Connect Nikon with PC
Using a USB cable or putting SD card into an SD card reader to connect Nikon with Computer.
Scan Nikon d70- Running the Nikon Photo Recovery,you can choose Nikon media drive and click "Start Scan" for scanning
Recover deleted photos
After scanning, you will see all recoverable media photos and videos with file type. At last, click "Recover" to recovering deleted Nikon D70 photos.
This Photo Recovery also can recover all photos files from Nikon D3100 like JPEG, BMP, TIFF, GIF, etc. Support all Nikon camera.
For full details please refer to Nikon D70 Manual.- https://guideusermanual.com/product-name-d70-manual&po=4425&lang=English
Nikon Coolpix S550 memory card problems
Your camera uses a different filing system than the other camera...they are not interchangeable.
1helpful
2answers
Nikon D70 data imprint
Sorry for the long answer, but this is complicated.
Some photo editors will allow you to set them up to display the date on the photo.
HOWEVER on all digital cameras:
The date taken is part of the image data that is stored in the file, but not as part of the image. If you print directly from the D70, you can set the date and data to print in one of the menus, but this only applies if you print from the camera. There is no way to actually put the date on the image like there used to be in some film cameras. Since the "picture" is now just a set of computer data bits stored on a card, disk, or other medium, the actual picture is defined by the jpeg standard, which is part of the ANSI/ISO/IEC organization. A camera manufacturer could add an extra bit of hardware to generate some kind of laser mark on the digital sensor in the camera, but I'm not aware of any camera that has this. For sure, the D70 does not.
In the various softwares that you can buy to read the file, the information in the file (like the date) can be interpreted and printed any way the software is programmed, including putting it somewhere on the printed output.
Camera will not power up changed battery just went dead Nikon D70
Fixing a Dead Nikon D70 - Green Blinking Light My first-generation Nikon D70, which I bought the day it was released to the market a few years back, died on me a few months ago. Without a card in it, it won't start, and when you insert a CF card in the slot, the green data-access indicator flashes on and off. If I hold down the Menu button, the menu flashes on and off along with the green LED.
d70_87x1.jpgAs it turns out, this is a known problem with the original Nikon D70 cameras, and Nikon USA has a service bulletin out on the camera body. They'll repair it free of charge.
So, if you have the same problem, visit this service bulletin page, http://nikonusa.com/Service-And-Support/Service-Advisories/D70-Service-Advisory.page click on the D70, and you can access a PDF file that you'll need to print, fill out and send to Nikon along with your camera body. Be sure to take your camera strap off and remove the battery, and don't send any lenses or other accessories.
Mine's on it's way to Nikon now - they say the turnaround is five days (plus shipping time).
3helpful
"FILE CONTAINS NO IMAGE DATA"
It may be of your new SD card. Try with another SD card. It may not show you File contains No Image Data. -Lalith
1helpful
D70 USB setting issue
Users of Windows 98SE, Windows ME, Windows 2000 and Mac OS 9.x may experience problems trying to download images from the Nikon D70 using Nikon View. Initial shipments of the D70 have the USB option in the "Set up" menu set to PTP - Picture Transfer Protocol. PTP is only compatible for downloading images with Windows XP and Mac OS X. To solve this issue please set the USB menu option to Mass Storage and then connect the camera to the computer. The D70's card will then mount like a removable disk and Nikon View will be able to transfer images
1helpful
NEF Image will not open - Macintosh
RAW NEF images from Nikon cameras are proprietary formatted raw data directly from the cameras's sensor. If the images are improperly transferred to the computer they will not be able to be opened and will give an "Unsupported File Format" warning. Macintosh OS X has an "Image Capture" application (found in: Hard Drive/Applications/)that can be used to transfer images. If "Image Capture" is used NEF files will be corrupted and will not be able to be read. Only Nikon View, or manually dragging images from the mounted card, should be used to transfer NEF's. To disable "Image Capture": Double-click to open the hard drive and then the "Applications" folder Double-click "Image Capture" From the "Image Capture" menu choose "Preferences..." In the "When a camera is connected" pop-up choose "No Application" Close the Preferences window and Quit Image Capture After disabling Image Capture, it will not launch when the camera is connected and you can use Nikon View to properly transfer NEF images.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
