Exercise & Fitness Logo
Posted on Feb 05, 2010
Belt slipping on Nordic Track c1900
My Nordic Track c1900 is slipping while walking and jogging.
  • Anonymous Mar 11, 2014
    Ilike dowloading drivers for this moterboard.
    Thank you very much.
  • Anonymous Mar 12, 2014
    I lost the manual and i need a new wristband for it too
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1729
Points
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Stopped in Belt had been slipping smelled hot but motor was barely warm. Was 30 minutes into workout and machine stopped. Electric panel works but motor won't run.tilt works
time to lube the DECK belt, use WD-40 or grease. do it by each weeks. Try to loose the deck belt. in the way that you lift the belt by 2" with your finger. Otherwise, you must replace the belt+deck. See if the belt drive is to tight. And take time for maintenance the motor, replace the carbon brush+and lube the bearing.
4helpful
Walking belt on NordicTrack C1900 is to loose, how do I tighten it? When walking on it when u get to level 4 it just about throws u
Tighten the rear roller bolts evenly with the unit off. The correct tension is when you firmly lift up on the right and left edges in the middle of the walking belt and get 2-3 inches gap above the walking board. If one side is looser than the other, the walking belt may wander sideways. Turn the rear roller screw on the side that it shifted to in a clockwise manner(1/2 turn at a time). Test on a low speed and adjust as needed. (you may manually recenter the walking belt with your foot if it shifted too far to one side and is rubbing on the plastic edges.) You likely have a worn motor belt that needs changing or even a pulley on the front roller that is slipping and needs replacing. They all cause slippage.
1helpful
My nordic track treadmill's walking belt stops when I start walking on it but the motor is still running although the front roller is not moving when I start walking on the walking belt. Do you think the...
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
10helpful
4answers
Our belt is slipping on our nordic track c1900 treadmill, how do i fix it?
I have the same unit. First, remove the hood. Then, the motor has an adjustment screw on the belt side of the motor. Loosen the nut a little, adjust the motor up or down to make the belt as tight as you can by hand, then re-tighten the nut. This always fixes mine.
Top NordicTrack Exercise & Fitness Experts
NOEL
NOEL
john h
ADMIN Andrew
ADMIN Andrew
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
