SOURCE: How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
SOURCE: I have a weslo cadence dx5 treadmill and i can't
go to:
http://www.iconservice.com/manuals.html
fill out form......search.... view manual in PDF Format
Print
SOURCE: given a Weslo Cadence 840 but panel is not providing read out
just got one myself not sure if you have yours question answered already but i will tell you anyway.. on the left hand side of your base read out there is a slide up panel and it takes 3 aa batteries to work the digital readout..
SOURCE: can not find my manual for my weslo cadence ts5
try this site and type in model and type...manual will be a PDF booklet
http://www.iconservice.com/CustomerService/manuals.do?dr=WL
SOURCE: Weslo Cadence 450 Treadmill Manual
When turned on it acts like the walking surface is grabbing.Itgoes and stops its not as bad when speed is increased,but it still feels like it is grabbing.
I need more information, what do you mean? what his doen´t
it will not turn on
I have a TX400 treadmill
If you post in here almost no-one will see your problem.
