More information would help. What are you running the signal into the TV with? Coax? Separate video/audio? To test the set if you have a vcr hooked up or available to hook up, input it into the tuner input and play a tape. Set the tv to either channel 3 or 4 (whichever channel the output of the vcr is set for, this can be determined by checking the menu or a switch on the back if it is an older vcr). If your TV is ok you should be able to see the tape which is playing. If not, and you still have snow you probably need a new tuner in the set. Let me know if you need more help.
hardrocko
