I have techwood receiver model number PLR85 the rear channels were working, then they quit..the speakers (checked them in front hook ups) work fine. inside there are little green plastic things (diodes?) with 2 wires what are they and what do I do??
The protect light keep comming on
The green light is signifying your receiver is going into a "self-protect" mode.
I have owned 3 of these receivers. They are vicious, pushing 400 watts. They get very hot.
The problem you're experiencing is the same problem I had. The issue is that your system has detected that you have a FAULTY FAN. The system knows it will over-heat without the fan, so it protects its self.
Change your fan. Problem solved.
Good luck finding a fan.
Ryan
Franklin, IN.
[email protected]
where do you find a fan?
where do i find a fan? my fan doesn't smell burnt at all
I have a Techwood PLR85 spearkers will not play, have replaced bus fuses 6v&7v fuses keep blowing out and still nothing
The people are loosing their moral while becoming modern. The
society needs to be attentive that moral value.
PLR Sales
My techwood digtal recorder keeps failing to record certain programs. saying recording failure?
Im havin some problem wht the delay what shounld i do an what is a delay is for
Ryan
Franklin, IN.
[email protected]
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Techwood 400 watt home stereo receiver. The Rear channels stopped working (speakers still work) replaced fuse...diodes??(green plastic with small wires that fit into board
inside by the rear channels. these came loose what do I do????
i can not get the surround to work
I have a Teachwood 400watt PLR85 and my speakers will not play and I have changed fuses. (Still Nothing)
i have a techwood plr85 speaker will not play
My b speaker wont work how do i fix that
