I can't find the code for my DVR box from Comcast. It's a ''Pace'' box and the few codes listed didn't work. 051 worked for my Motorola Comcast box, should it work for Pace too?
Locate the code of your device in manufacturer's codes on the back of the user guide. Brands are listed in the alphabetical order with the most popular codes listed first.
This may not be a definite answer, but it may provide a hint what codes to try. Although the standard Cox cable box code for my Philips universal remote, 4200, worked for the 9865HDC, the standard code for my GE 24959, 0529, did not. Since Cisco acquired the Motorola cable box division a few years ago I tried all of those codes, but none worked. Then I noticed a single code 0506 for DVR under Motorola. It worked like a charm, even the dedicated DVR List button on the GE 24959. Hopefully you can find a Motorola DVR code for your universal remote.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://homenol.blogspot.com/ http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
I have the same problem. The only time that I can get it to work is whenever I turn on the cable box the home theater system turns on too. When I use the DVR it will turn it on too and want to play the CD/DVD. I have a Comcast Motorola DCH3416 DVR box.
I just programmed my comcast remote for my Samsung v1000, My comcast remote is very similar to the 3-in-1, but has a few more buttons on it (on the Comcast site, my remote looks like the DVR 3 remote, but I don't have a DVR). The code I used was 21044.
By using this code, the play/stop/rewind/ff buttons all work. I didn't test the record button. The Info button worked as "Display" and Exit button to work as Audio Source (HiFi/Mono). However, the Volume and Channel controls did not work.
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice 2. Type 994 3. Press and release SETUP 4. Type 32975 5. Press and release VOL+ The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below: Vol+ = 32975 Vol- = 31951 Power = 32719
The answer depends whether its a Comcast DVR Remote or a regular one. The DVR codes are 4 digit -- the others are 5 digit. I got 0060 to work for my DVR remote.
I HAVE A SKY+ BOX ALSO , AMSTRAD MAKE ON BACK, TRY SETTING IT TO DIGITAL RECEIVER INSTEAD OF SAT RECEIVER, THEN SELECT THE MAKE PACE, THEN CODE NO 8 ( B676 ) THIS DID TURN OFF MY SAT RECEIVER BUT THEN ACCIDENTALLY SCREWED UP THE NEXT STAGE AND I CAN NOW NO LONGER TURN THE SAT BOX OFF,
BUT YOU MAY HAVE MORE LUCK, IF YOU DO NOT SCREW THE NEXT STAGE UP, BEST OF LUCK
