HP Pavilion dv4-1140go Laptop Logo
Posted on Feb 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have hp dv4-1465dx, how to reset bios without having OS
I have hp dv4-1465dx, i was installing win 7 crack, there was some bios setting in that crack,after i restarted that, it doesnt go forward only HP logo comes in front, doesnt enter to bios by pressing F10, nor go to system recovery when i press f11, the lapotp isnt hanged, when i press num lock or caps lock, the light turns on,,
i think there is bios problem, plz someone tell me some bios reset utility which i can install withoout having windows, i mean any bios reset utility regardless of operating system, in DOS etc,
Anonymous
Level 2:
  • Expert 358 Answers
  • Posted on Feb 07, 2010
Anonymous
Expert
Level 2:
Answers
358
Questions
0
Helped
120433
Points
935
Was Windows 7 the operating system that came with
your System? If not, What I would advise you to do
is this:
Check HP website to find out if your Laptop supports
Windows 7.
If it doesn't, then I would advise you to
PLEASE change it back to the operating system
that came with your system, or better still, the
operating system that it supports.
The reason is because that is exactly what I faced
two weeks ago....
I changed the operating system for my PC to
Windows 7 ( Even though it doesn't support it)...it
worked fine for a while, then later it started to develop
faults after a while...like stuttering, mouse pointer
moving round the screen, graphics displaying
improperly...etc.
I first thought it wasn't a big deal, so I fixed it by
repairing the drivers, and it worked fine once again...
After using that same crack that you said you used,
I started getting "Multiple Hardware Error"!
It would just Power on, Show HP Logo, Show
Wireless LAN indicator Led ON, and It will freeze
there. I could not even enter the BIOS.
In short ....Now as I'm typing, the system is
with HP Service Centre for they have to change the
Mainboard Outrightly!
So PLEASE, if your system was not specified
Windows 7, use the Operating Systems that it
supports.
Then go to HP Website and download the original
BIOS settngs for your Laptop then repair your
system with it.
But if it is the one that came with it, then let me know
so as to tell you some quick fixes.
Hope this helps you out.
Goodluck and thanks for using fixya!
1 Related Answer
PaulB183
  • 61 Answers
  • Posted on Feb 05, 2010
SOURCE: i have hp dv4-1465dx, how to reset bios without having OS
I'll spare you the rant on dealing with "cracks" but will say that damaged or corrupted firmware in BIOS's is a major problem that is not always correctable. It is possible you have bricked your system. Especially if the BIOS is not in a socket but hardwired to the mainboard and can't be easily replaced.
The problem is that if the BIOS is the issue you aren't going to get past POST to read anything from any disk [hard, USB, CD-Rom] so the system becomes totally unbootable from any source because the system is unaware of any of these sources as the BIOS firmware hasn't provided the system the data to access them. None of the I/O's will function so you won't be able to flash the BIOS ROM with an replacement for the damaged code.
Your best bet is if your BIOS is socket monted, in which case you can purchase a replacement and swap it out for the damaged one which will resolve your problem as the code on the new one will be intact.
You can do it even if its not socketed, but un-soldering and re-soldering a BOIS chip onto a mainboard without damaging the tracings is no easy trick even for an accomplished repair tech.
Sorry I couldn't do better for you. I hope it works out.
1helpful
2answers
Hpw can i factory reset a locked hp elitebook 8560p laptop without a reset disc and forgot my password
why ask here, ask hp.
sharon, you never said what PC.
Bios admin
Bios users.
windows login, local or live.com
we can not guess what is on your screen
but if the PC BIOS locked you out that, a TPM chip +UEFI lock.
and only HP can crack that. ask them.
is this windows 7./9 or 10 PC
why post lacking what OS you run. (makes answers wrong.)
http://pcdied.com/passwords.html
or learn to use your cell cam and post photo of the failing screen.
and magic happens, add it click photos below.
2answers
Format my hp 635 laptop
Make sure you have all your data backed up
Also make sure you have your re installation disk and proper cd keys to perform a clean install.
power your unit - press F9 for boot options - insert your 7 disk into cd rom and choose boot from CD-ROM. Follow instructions provided from install disk.
How to choose priorities for booting when installing windows
What choices do you have/want?
BIOS settings are for media like hard drives, cd drives, usb drives.
Windows boot manager for OS choices like XP, Win 7,
Digital fingerprint reader not working
What OS are you using ? Did you install the drivers and the app for it ? Is your fingerprint reader enabled in BIOS ?
If you have Win 7 64 Bits -
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-67648-1&cc=us&dlc=en&lc=en&os=4063&product=3815320&sw_lang=
Post here results.
If you are not using Win 7 64 : choose operating system from here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4063&lc=en&cc=us&dlc=en&sw_lang=&product=3815320
and in iput devices you will find drivers for fingerprint reader.
Good luck
11helpful
5answers
How to reset hp probook 4310s embeded security password
If your hp computer is installed with Windows 7, following the video to learn how to reset hp computer security password with Windows 7 Password Genius
https://www.youtube.com/watch?v=I5HzG7fb-Wg
If your hp computer is installed with Windows 8, and the password is your only admin password, refer to hp computer Windows 8 admin password reset.
1helpful
I need to install win xp on hp 540 and ineed to know if i have to configer from bios or i need win xp sata support OS?
Befor installation you need to follow the following steps
1. Start your laptop and press F10 continuously to go to BIOS setup.
2. Go to "System Configuration" -> "Device Configurations"
3. Set "SATA Native Mode" to Disabled.
4. Start the installation while keeping a finger on "F7" key.
5. After some time there will be continuous beeps.
6. Remove your finger for sometime and then continuously press "F7" key till the beeps are repeated. This is done to disable your BIOS ACPI.
7. And then do you normal Xp installation.
8. This should do
I am trying install winodws7 on HP Compaq 610 having ATI Radeon Catalyst(Current OS winXP Pro SP2). But in the installation window it is showing the CD/DVD driver missing message. So, googled it and found...
Hie there i have installed and reinstall Win 7 Ultimate on Multiple Compaq 610's without any problem.
i once encountered a prob like this one but was lazy so i removed my Hdd and formatted it elsewhere and Walaa my prob was gone. i didn't have to upgrade or downgrade my bios and am still using the same laptop 2day. Just make sure you DVD rom aint damaged.
good luck
1helpful
3answers
I installed a win 7 beta version on my pc..and when i wanted to revert it into vista again it won't install anymore to any os except win 7. When i tried to install vista it cannot detect my HDD, and when i...
To make sure you install back again your Windows Vista and Windows XP is this.
First:
  1. Go to Bios Setup and change the setting of your Hard Disk drive from Sata to IDE mode.
  2. Boot priority the CD/DVD Rom to run your Bootable CD/DVD.
This setting are quietly working, good luck!
Error installing windows xp
hi! there,set up exe. that was when your setting up win 98 you have to install that came from floppy disk before you can install win 98.there is an os win 98 in your system you have to delete that previous os before installing another win xp.restart ur computer. press F2 to open your bios set-up . then select bios set-up priority your cd-room drive second,your hard drive. last, quit and save set-up. and then your computer will restart. insert your cd windows xp then reinstall your window xp. delete the previous os then follow the set up on your window xp until you install your new window xp.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
