The M407 uses standard AA batteries, rechargeable or disposable. If you want to use rechargeables, you should be able to buy a suitable charger at just about any department, electronics, or office-supply store.
The camera won't charge the batteries, and never try to charge disposable batteries in a charger.
It could be something wrong with the power board. If you have an external charger to charge the batteries. After fully charged tried to take as many pictures as you can. If the battery discharge fast, that mean something is wrong with the power board.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
The issue is probably the button board on the camera. To open the camera, remove the six screws and pry open the camera from the bottom of the camera to remove the outer casing. Turn the camera so that the LCD is facing. Remove the aluminum frame around the LCD that holds the button board in place. Check the button board for mis-aligned or damaged discs (ie playback or view buttons) The discs are taped and may creep out of position. If they are out of position, push them back with the blunt edge of a screw-driver. If it looks fine, reassemble the camera.
is it a brand new camera? how long have you had the camera? are u puttin the batteries in the correct way? maybe u can try different batteries for now see wat happens if not write me back.
The camera is recharging the flash. (possible cause)
Solution: It takes longer to charge the flash when the battery is low. If you see this message alot, you may need to replace or recharge the battery. Hope this helps!
WOW: All three Solutions Work Fine. I Removed the 6 small bolts and took the camera apart. lifted the tape and cleaned the contacts u;nder the tape with alcohol, let them dry then replaced the tape, lineing up the contacts on the tape with the ones on the body of the camera. Put the camera back together and put back the 6 bolts, inserted the batteries and presto: the camera worked. Thanks for the info , it really worked. Wes Reed
