I have a sharp tv and almost everyday for the past week my tv will just close while im watching something and it wont turn on unless i pull out the electrical plug from behind and that to if i leave it out for about hour if i push the plug back in after 2 minutes the tv starts for around 5 seconds and then closes again can you plz give me a way where i can stop this from happening??
TV's use high voltage to generate the stream of electrons traveling
across the picture tube hitting the screen and lighting it up (thus the
name Cathode Ray Tube). It takes about 25,000 volts to do
this. In normal air, it takes about 1000 volts to jump an inch of
air, so the high voltage transformer needs to have good
insulation. It generates the voltage through a technique of
charging the transformer's magnetic field with a low voltage of about
140 volts then letting it go where upon it flys back out the high
voltage side at much high levels (Thus the common name
flyback). A most common failure in a CRT type TV is for the
insulation to crack in this transformer which is a unique component for
each model of TV and leak out the current overstressing the circuit
driving it. You can liken it to a little bolt of lightning
getting loose in the circuit and has the same sound on a smaller scale.
It would be well to replace your flyback transformer before it gets
worse and blows up something else as well. Best done by a
professional used to handling high voltage. The picture tube can
retain voltage even when the TV is unplugged for some time, and
replacing the anode lead (the big red one) can be dangerous.
Hope Ya Fix It!
