Hi David
I think you should replace the lamp.
SOURCE: Sony VPL-CS1 projector
Hi there
You should first check if there is any visible damage on your lamp. If not then it could be a faulty Ballast ( lamp powersupply )
SOURCE: power up
Hi mick1907
Take out your lamp and check for any irregularity like marks or discolouration.
If there is no visible damage - put back the lamp and take of the top cover - start the Projector and check if all your fans are running - that is if the machine starts at all.
If the unit doesn't start up at all you will have to replace the Mainboard.
SOURCE: Intermittent lamp turn off
your lamp is fried just change it i did the same to mine and it works just like a charm
SOURCE: Sony Projector
Ok we're back to the flashing lamp cover LED. The green flashes you are seeing is the TV trying to start up. After it tries for awhile, it will eventually shut down and display an error code, in this case, the lamp cover LED flashing which means either the lamp cover, filter cover or main cabinet sensing switches are not closed, are intermittent or have some kind of wiring issue. A solid lamp cover light (no flashing) would point to the lamp and lamp drive, but the flashing light points to the switches. Give me an email address and I'll send you the training and troubleshooting manual so you can see for yourself. Any ther help needed, please don't hesitate to ask.
