Question about Freezers
Frozen freezer I have a jen air side by side refrig. and my freezer is frosting over. What are the common parts that need to be replaced to solve this problem?
  • gr8fdead Feb 20, 2008
    the model number is JSD2789AEB
  • gr8fdead Feb 21, 2008
    I can not find the defrost timer??
    President:
  • 1,314 Answers
Send me the model number and ill take you through it step by step hold my rating till we are done you have a defrost problem its going to need either a defrost timer a defrost thermostat or the heating element
Posted on Feb 20, 2008
  • robert samples Feb 20, 2008
    ok first locate the defrost timer in the refrigerator compartment control box there should be a hole there that you can stick a screwdriver in a small one .Next after locating the defrost timer pull the cover off the freezer where all the ice is and leave the freezer door open.Locate the defrost thermostat it should be on one of the lines coming down to the evaporator its the alum honeycomb looking piece under the cover that you removed and the defrost thermostat will be a silver disc round piece with two wires clipped to one of the copper lines coming into the evaporator with two wires on it one wire will be power the other will go to the heater now here we go.With your screw driver slowely turn the timer clock wisr till the unit shuts off and you hear the fan in the freezer stop.Check your watch and note the time then watch the freezer side where the evaporater is to see if the heater comes on itll take afew minutes 5 or ten the first thing you will notice is the frost at the bottom where the heater is getting waterly looking .Then let it run for thirty minutes if it doesnt cut back on by then replace the timer if after five or ten minutes you dont see the heater on then turn off the unit at the freezer control and unplug the defrost thermostat or you may have to cut the wires on the thermostat and wire them togeather to by pass the defrost thermostat .Then turn the unit back on .Now if you by pass the thermostat and the heater comes on then keep watching the time if after thirty minutes the unit clicks back on then you have a bad defrost thermostat. if you do all this and the heater still doesnt work you have a bad heater if the unit times out and all the frost isnt melted just turn the timer around again till the ice melts when all the frost is gone if you had to by pass the thermostat then turn the unit off again seperate and tape the wires from the defrost thermostat till you can get a new one dont leve them in a bypassed state .
  • robert samples Feb 21, 2008
    well it may have an adc adaptive defrost cotrol your model is just about they changed try this
    1. Disconnect the unit from the power
    source.
    2. Open the fresh food door and remove
    any items on the top shelf.
    3. Remove the light shield and the temperature
    control housing (see steps 3
    and 4 replacing the timer).
    4. Connect the refrigerator to a wattmeter.
    5. Make sure compressor is running (cold
    control closed).
    6. Using an insulated number 22 jumper
    wire short between L1 and Test; this will
    put the refrigerator into a defrost for
    approximately 23 minutes.
    dont worry about the watt meter part
SOURCE:
2 lights on bottom outside on food defrosting
5 Common Freezer Problems - APWagner Appliance Parts ...
https://apwagner.wordpress.com/2008/.../22/5-common-freezer-problem...
May 22, 2008 - Answer 2: The first thing to do is to set the thermostat to a colder setting. ... The compressor is at the back of the freezer near the bottom. ... You can manually defrost your freezer by turning it off for 24-48 hours and turn it back on to see if it begins to work ... Verify that the door light switch is working properly.
Why is my freezer suddenly frosting over? - Askville
askville.amazon.com/freezer-suddenly-frosting/AnswerViewer.do?...
May 30, 2009 - For the last 2 months my freezer has had a layer of frost over ...Normally when frost build up occurs its because warmer outside air is getting into thefreezer and the ... Or you may have an issue with the defrost heater, thermostat or timer. ... If there is no light you may not have a frost free freezer which means ...
Why is my upright freezer freezing at the bottom but warm on ...
www.shopyourway.com > Patricia Delugas > Questions
Food in the drawers is still frozen, but above this level is room temperature to the touch. ... the lower inside pane to remove ice from around the fan and evaporator (mostly refrozen fluids from thawing foods on the upper shelves). ... 2 Answers from these members: ... Outside is not warm (as usual). Yellow light remains on. 2 ...
[PDF]All about the of your Freezer - AJ Madison
Jan 20, 2016 | Freezers
My freezer is not cold. The temperature dial reads 1-5 then an igloo and a snowflake. Do I put it on the snowflake to get it cold or the igloo?
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Take care in solving the problem....
May 01, 2011 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Frosting up in the freezer and not cooling in the food compartment kenmore 363.9557852
It sounds like you have a defrost problem.
All the cooling for both sections takes place in the freezer behind the back wall. A fan back there distributes the cold air throughout the freezer and fresh food section. Every 8 - 10 hours a heater comes on for about 20 minutes to eliminate the frost from the evaporator coils back there. If this defrost cycle fails the frost will build up to a point of no air flow so the fresh food side and most of the freezer start to warm up.
The best way to take care of this is to turn it off and unload the freezer, take the shelves out and the screws holding the back panel inside the freezer out. Remove the back panel from the freezer. Use hot water and a hair dryer to unthaw the ice and frost, you will need lots of towels as the melting will bring lots of water on to the floor. Once the frost is gone you will need to install this part WR51X443. The picture below shows it. The kit contains new heaters and thermostat.
Apr 26, 2010 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Jen Aire Fridge ice maker fingers are below the
This one you have to take out the ice maker and run hot water from the kitchen sink into the tray to get the ice out. need model number if you want detail explaination how to. or just use a hair dryer that will work to!!! if fingers dont rotate after defrost ice then the gears are stripped, replace ice maker
Mar 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
The refrig does not defrost. frost is
This is a serious problem which you have to fix as soon as possible. if you don't act , you will pay $200 for repair or $500 for a new one.
Are you ready?
Do you know what we call cable ties? you will need one. And unplug your refrigerator, very carefully, turn your refrigerator in the way you can see the back. . You will see a small pipe , very small going from the condenser( part from the compressor) just after the filter. See if you can put this small pipe in contact with the part who frost and with cable ties ( must be metallic) tie together. at two places. Problem gone forever . Enjoy and don't forget to vote for me.
Sep 15, 2009 | Freezers
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Frig no longer cold
Hi, look inside freezer and see if there is a frost build up on the rear wall. Also listen to see if the evapotator fan motor is running.
Please let me know so I can assist you further.
Vic
May 27, 2009 | Frigidaire Freezer Refrigeration White...
Frost free fridge/freezer - not cold in fridge
The most common problem with refrigerators not cooling when the freezer cooling is the fan which supplies cold air to the freezer. Not easy to get to in most cases. Another problem is the vent to the fridge part is blocked or not operating with the adjustment control.
Nov 27, 2008 | Freezers
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Freezers Logo
362 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
