If you prefer the convenience and don't mind the extra cost, you can buy shredder lubricant sheets at an office supply store and follow the directions on the package.
Or for a far less expensive method, buy a bottle of generic mineral oil (or baby oil) in the drug store. Spread 1/2 tsp of the oil onto a piece of letter size scrap paper, and run the oiled paper through the shredder. Then run the shredder in reverse for a few seconds and in forward for a few more seconds to spread the oil over the shredding cylinders. That's it.
SOURCE: NoviTech Paper Shredder will not feed paper forward.
Solution 1 worked for me. I unscrewed all 7 screws, pulled apart the cover carefully. Beware, there are wires attached. you can lay it side by side.
The activator is the white plastic thing. You need to make sure that it sticks out and as the paper goes from the top, through the cover, it hits the white activator.
At the end of the white activator, you see it has some plastic to push on the metal strip. This engages the forward motion. You'll here a click if you test the paper going through. This click is the sound of telling the motor to roll forward.
I think it got knocked out of place when I tried to insert a CD into it. Luckily, I didn't buy another shredder because of the Best Solution in this forum. So thanks for your help!
SOURCE: REPLACEMENT INTERMEDIATE DRIVE GEAR FOR NOVITECH
Get me the model and serial number or just call Fellowes direct. They will sell you the part.
If not. Call me with the information and I can order it for you.
727-773-8973
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
SOURCE: My NoviTech Shredder shreds fine but will not cut off after it fi
Blow some canned air down into the feed slot to clean the sensors
