The washer requires a structurally sound floor for shake-free operation. anything other than a cement/concrete slab will shake. even on a tile floor there is slight shaking. a vinyl over plywood floor just won't cut it. a pedistal makes matters worse; as you're bringing the center of gravity up and away from floor.
I have this same problem and I have had two different repairmen out and they can't seem to fix mine either. We shouldn't have to set it on the floor and not on the pedestaly. Mine just started doing the vibrating to the point it sounds like it will fall off the pedestal. There has to be something that can be done or maybe they should just do away with the washer . Please somebody do something for us that have that problem.
