Belkin Wireless (F5D7130) 802.11g/b Wireless Access Point Logo
Posted on Feb 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i reset the wpa key back to default - Belkin Wireless (F5D7130) 802.11g/b Wireless Access Point
Anonymous
Level 3:
  • Belkin Master 32,281 Answers
  • Posted on Feb 04, 2010
Anonymous
Belkin Master
Level 3:
Answers
32281
Questions
Helped
7911596
Points
102259
You can reset the Belkin back to the default settings by powering up the router and press and hold the RESET button on the back of the router for 7 secs.
The router's configuration URL is http://193.168.2.1
and the default password is blank (just press Enter)
Need wpa key to connect to network
If this is your home computer, you are probably going to have to reset the router if it is yours
here is a guide
http://support.netgear.com/app/answers/detail/a_id/9665/~/reset-and-restore-the-netgear-device-to-factory-default-settings
Need wpa key
WPA keys cannot be easily or quickly obtained, your best option is to reset the router and from there create a new key.
To reset:
With the router on, hold down the "reset" button on the back for 10 seconds. This will reset your password and restore factory default settings.
5answers
Cannot find wpa code
You can factory reset the router using the small button on the back, hold it in for 30 seconds with the power on to the router. This will clear all settings from the router including the password, so you will need to set up the router again after the reset.
How do I reset my security key
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your computer's LAN port, open a browserand enter the D-Link's configuration URL. OR open the browser on your laptopand enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password. You can now go to the wireless settings and configure the SSID and WPA or WPA2 encryption key.
What is a security key
WPA (Wi-Fi Protected Access) is an advancement over WEP (Wired Equivalent Privacy). While connecting to a home network, you are often asked to insert a WPA key or a password to which users often ask, "How Do I Find My Computer's WPA Key?" WPA stands for Wi-Fi Protected Access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over(Wired Equivalent Privacy) Wep is standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
While connecting to your home network, you are often asked to insert a WPA key. This WPA key is either located in the modem or in the router you are using. In order to find your computer's WPA key, follow the steps given below:
How to find your computer's WPA key Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To Reset a modem/router, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long. For minimal security, you can choose 8 characters key, like "iN\/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBD\m+oMp$nrXj5XPVRTvVA5fpwGSGI\RVz4RdQ7V3y\l$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Note: The procedure shown above is common to most of the modems/routers. If this doesn't apply to you, check your modem/router's manual to find the wireless security option.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
How do i connect to internet with ps3, wireless, what is a wpa key?
WPA stands for Wi-Fi protected access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over WEP (Wired Equivalent Privacy) standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
You can correct this problem by entering the WPA Key into your PSP's Network Settings. But before you do that you need to know what your WPA Key is...
To reset a Linksys modem/router or Belkin one, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
For minimal security, you can choose 8 characters key, like "iN/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBDm+oMp$nrXj5XPVRTvVA5fpwGSGIRVz4RdQ7V3yl$P1NrT9Be".
Cant find my wpa # needed to reconnect my router (TM-G5240) to my x-box live account
For routers, there no way to see what the WPA key is. Once you check the Web UI of the router and check the security, all you will see are asterisks (*********). Because WPA is a security and needs to be hidden. As the owner of the router, you should always remember what your WPA key is.
In order to resolve this issue, you need to reset the router back to factory default, set up a new WPA key and save it.
Or you may contact the manufacturer of the router and see if they have a record for your router
Have a great day!
2answers
Just bought second hand router belkin 54g trying to set up with ps3 it is asking 4 a wpa key and i dont know what to do can you help
the old owner of your router know the wpa code he/she inputed you must ask him wat is the wpa code since you are now the new owner you shold chnage also the old wpa code to new one....
2answers
Wpa key on modem
you need to log in to the modem itself. Type the following in your internet explorer bar:
linksys: 192.168.1.1
dlink: 192.168.0.1
any other models, you need to look at the instruction manual to find the correct address. Once in the setup menu, look for wireless settings.
Unable to setup wireless network
I know exactly what has happened
u did not knew the password for router manager
u reset it
After reset router , it came back to its factory defaults, now the password will come back to its factory defaults ( if u still dont know the factory defaults password, check manual provided to u with this router )
After reseting , as router came back to factory defaults , it also changed the wireless encryption key or WPA password with which u were able to connect earlier to its factory defaults original key and due to that reason u are getting limited or no connectivity coz the WEP or WPA key has changed.
Solution: IF U know the original wireless key or WPA key try to reenter it and see whether it connects or not
if still does not work
Then connect ur PC or laptop with ethernet or LAN CABLE (CAT)
Your internet will start working with the cable
NOW u will be able to open the router manager page
Type the factory defaults password and log in
Then goto the wireless settings page and check what is the WEP key stored in ur router and also try to channels of the router and see wherher it increases the signal strength or not
Once you have got the key from the router manager page
Try to reenter it and then surely it will work.........
Best of luck
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
