I am having the same problem with our control steam sounds thomas train. I've been searching to no avail. If anyone can help me please leave me a message thank you!
A few things can cause this: The battery is weak/bad. The connector at the battery might be worn out and have intermittent contact. Those are fairly easy things to check. Next, the GO button might be worn out internally (high resistance contacts)-believe it or not, the whole motor current goes through that switch. You would need to remove top of the roof to access the button. Or, open the speaker cover, pull out the control board and bypass Go switch wires to check for train proper operation. As you are already there, inspect the control/sound board. The last thing that comes to my mind is the motor itself, it is under the seat. Check contacts to motor, plus you can spray contact cleaner or, if you don't have anything else, alcohol. Avoid using WD40 - it does the job, but collects new dirt very very fast). There is always a chance of pinched/loose wire, or mechanical problem with gear assembly/jamming or so.
well youlle realy need to buy the batteries that could fit and move into the toy you bought. also if the battery you used dindt work. maybe you should try a medium sized battery.
Hey. I was looking for the same thing and found this answer on yahoo answers:
"loosen the phillips-head screw on the underside front center of the jet engine train (you might not have noticed it - it is behind the coupling magnet assembly, which you can move to the side and also has an opening to access the screw) - once the screw is loosened, you can lift up the 'jet engine' from the base to access the battery enclosure" http://answers.yahoo.com/question/index?qid=20071225073953AAHYJKb
