I couldn't find any drivers available for Windows 7. However, you may be able to run it in 'Compatibility Mode'
See: How to run in compatibility mode Windows 7
http://www.sevenforums.com/tutorials/316-compatibility-mode.html
US-122 Windows Drivers: v. 3.40
Release Notes (download)
- v. 3.40
Windows Vista and XP Driver (download)
- v. 3.30 32 Bit
Windows XP driver (download)
- v. 3.30 64 Bit
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thanks!
1.I have this same issue and I have found no Windows 7 drivers yet for the midi interface I have.
There are none at this time unless they as I have been informed have developed them in the last month or so.
I have Windows XP professional also and I have a latency issue with this Operating system and the processor will not use the drivers for Windows XP mode. I have been told by the manufactuer to purchase a new updated unit to see it will be compatible with Windows 7
2. I suggest that you prepare a hard drive with Windows XP and install it in the new PC ( I am assuming that you have a duo core PC with 32 or 64 bit processor) which will if using a 64 bit will not work for a 32 bit device.
3. Check with the Tascam manufacture to see if the have upgrade the drivers for your Window 7 PC.
SOURCE: tascam US-122 USB Audio/MIDI interfaces driver
the software is made by Steinberg and uses ASIO drivers that are at the address i gave you http://www.tascam.com/details;9,15,69,19.html
works fine on my XP machines
