Question about Learning Curve Toys Thomas the Tank Engine Track Rider
I have a Thomas the train battery operated engine and don't know how to put a battery in it. It is die cast and has a screw on the bootom that is a phillips shape ( I unscrewed that but it wouldn't come apart because there are also 2 triangle shaped scerws. Please help.
    New Friend:
Re: istbruno
my daughter told me, to squeeze the sides of the train and pull up and there is where the battery goes.
i had the same problem.
hope this helps
Posted on May 22, 2010
    New Friend:
Just take the regular screw out.. then pull the blue part (the top) from the black part (plus wheels). It'll come apart.. also: the front (where the screw is) comes apart FIRST.. because the back part is kinda into the back of the train. Try it.. it's easier than you think.
Posted on Jul 21, 2010
    New Friend:
  • 23 Answers
The triangle shaped screws are the same type found on Nintendo DS systems... they're called tri-wing. I bought mine off eBay for less than $2 shipped from Hong Kong.
http://cgi.ebay.com/Tri-Wing-Triwing-Screwdriver-For-NDS-DS-Lite-Wii-GBA_W0QQitemZ200400707580QQcmdZViewItemQQptZVideo_Games_Accessories?hash=item2ea8d01ffc
Posted on Feb 03, 2010
SOURCE:
Cant get the steam to work on the engine have put in water and new batteries and the steam is still not working
I am having the same problem with our control steam sounds thomas train. I've been searching to no avail. If anyone can help me please leave me a message thank you!
Jan 12, 2013 | Tomy THOMAS FRIENDS REMOTE CONTROL STEAM...
How do I change the battery in a motorized wooden railway engin for thomas the train
2 options.
1.if its the kind that fits on the wooden track look for a screw (philips/star screwdriver) on the underside of Thomas near his face. The body shell should lift off.you will then see the battery.
2 If it's the plastic blue track you have to squeeze the right center wheel and left center wheel. Thomas has 6 wheels so the 2 center/middle wheels, after squeezing this will then make the top portion pop off.
Jan 10, 2011 | Thomas and Friends Battery Operated Train...
I through away directions by mistake. How do I put the battery in Percy. Thanks.
My child has a similar train but it is a Thomas instead of a Percy. There is probably a screw on the bottom. My son's train has three screws and the one in the middle (+) is the one that opens the train so I can put a battery in it.
Nov 29, 2010 | Seth Thomas Thomas & Friends Percy Train...
My thomas the train ride on toy wont move unless you assist it by turning the wheel after pressing the go button
A few things can cause this: The battery is weak/bad. The connector at the battery might be worn out and have intermittent contact. Those are fairly easy things to check. Next, the GO button might be worn out internally (high resistance contacts)-believe it or not, the whole motor current goes through that switch. You would need to remove top of the roof to access the button. Or, open the speaker cover, pull out the control board and bypass Go switch wires to check for train proper operation. As you are already there, inspect the control/sound board. The last thing that comes to my mind is the motor itself, it is under the seat. Check contacts to motor, plus you can spray contact cleaner or, if you don't have anything else, alcohol. Avoid using WD40 - it does the job, but collects new dirt very very fast). There is always a chance of pinched/loose wire, or mechanical problem with gear assembly/jamming or so.
Oct 02, 2010 | RC Thomas the Tank Engine
Dont know how to change the battery in Thomas Jet engine.
Hey. I was looking for the same thing and found this answer on yahoo answers:
"loosen the phillips-head screw on the underside front center of the jet engine train (you might not have noticed it - it is behind the coupling magnet assembly, which you can move to the side and also has an opening to access the screw) - once the screw is loosened, you can lift up the 'jet engine' from the base to access the battery enclosure"
http://answers.yahoo.com/question/index?qid=20071225073953AAHYJKb
Dec 27, 2009 | Learning Curve Toys Thomas the Tank Engine...
Where do I put the battery for the HIT motorized Thomas train
i will try my best to help, i had the same problem with my sons as well..i was in the same situation:).You have to take the top of the train and the bottom of the train apart, seperate the top & bottom,then the battery compartment is inbetween the two..sounds confusing i know..they are very hard to pry apart.Hoped I helped!
Jul 06, 2009 | Hit Thomas and Friends Trackmaster...
Peg Perego Thomas Train Track Rider
I cannot promise that this is the problem, but this is where mine was broken, and you may be able to fix yours this way.
I was able to remove the plastic around the tender and access the motor. Using alligator clips, I was able to connect the battery directly to the motor, bypassing the circuit board. The motor functioned, therefore the only component that seemed to be defective was the circuit board, located behind the speaker in the engine unit.
As far as I know, the only place to buy a replacement circuit board is from www.tigerimports.com. Search for part number MEVA0024. Cost is around $15 + shipping (around $6 or so).
I should be receiving this part by the end of the week and will report if it fixed the problem.
Thanks for using Fixya. If I didn't help your situation, please DO NOT label this advise as "inappropriate".
Mar 12, 2009 | Toys
Learning Curve Toys Thomas the Tank Engine Track Rider Logo
4,079 people viewed this question
Top Learning Curve Toys Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Learning Curve Toys Toy Expert? Answer questions, earn points and help others
