HP Photosmart C4180 All-In-One InkJet Printer Logo
Posted on Feb 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printing blank pages
I did some scanning of photos yesterday, and now when I try to print a document, I get blank pages. Please help.
Mike
Level 2:
Scholar:
  • Expert 57 Answers
  • Posted on Feb 29, 2008
Mike
Expert
Level 2:
Scholar:
Answers
57
Questions
0
Helped
17491
Points
166
Make sure your set to "print" and not scan. The blank pages may be a 'print' of the lid on your scanner top
1helpful
Why does my printer feed through blank paper when document sent to print
Make sure your document is not blank, and the document has no blank pages below the first page.Also check your print Q and clear it before printing again.
5530 envy prints blank pages
Please try making a COLOR COPY of a document or photo. Does it print ?
If Yes, download HP Print and Scan Doctor from www.hp.com/go/tools to resolve the printing issue.
If No, click http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03743678&lc=en&product=5304883&tmp_track_link=ot_search to access the steps to resolve the issue.
2answers
Prints blank page
Have you checked the print que
Printer problems can be a real hassle.
From time to time, due to document layout or settings on your computer, in your software of choice, or even on your printer, a blank page may get "printed" with the rest of your document.
Fortunately, this issue is a simple one to troubleshoot.
Click "Print Preview" when you are finished with your document and ready to print.
Observe your document.
If you see an extra, blank page, you have created a second page.
To delete the second page, close Print Preview, go back into the document and eliminate any blank lines in your documents that you may not need.
You may also find an inadvertent page break at the end of your document.
Place your cursor on its symbol and delete it.
Locate the symbol by clicking on the Show Formatting paragraph icon in the toolbar.
Circumvent this "ghost page" if you do not see a second (or additional) blank page in Print Preview.
Specify the number of pages you wish to print, within the Print dialogue box.
This is typically done by selecting the "Print From" option, then entering the page numbers desired.
If your document happens to be ten pages (without, of course, that final blank page), then enter in the "Print From" field the numbers "1-10".
This will print only pages 1 through 10, without an eleventh (blank) page.
My EPSON Stylus Photo 1400 Ink Jet Printer is printing blank photos. The ink levels are fine, it's feeding photo paper fine, it's making the same noise as it does when it prints but the photos are...
Your problems states that photos are being blank when trying to print it.
Please try these tips.
  • Make sure your printer is selected in the Print window or in the Macintosh Page Setup and Print windows.
  • The print head nozzles may need cleaning.
  • Make sure your printer software settings are set for the paper size you're using.
Plus,i also wanted to know if you can print ordinary documents or print a test page.
Hope this helps.
Thanks,
FixerDelta
My printer scans and prints ok. but doesn't print documents from my documents. Microsoft reinstalled new driver with no results. Printer makes noise as if it were going to print but all I get is a blank...
first try to print windows test page from the pc and check out.if windows test page prints ok then try to print from my documents.but if windows test page does not print that means drivers are not got properly installed.
click stat---click settings --- click printer and faxes-- a page will get opened-- on that page you will see you printer icon-- right click that printer icon ------ and click the last option called properties ---- a page will get opened.---- on that page on lower right corner you will see print test page option--- click that and see if that page prints.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Prints blank pages
hi jcruisedirec
Test print shows that there is no problem with he printer.
Do this:
Type just one or two words in a new document and try to print. Before printing, look at the print setup and make sure you have the correct printer name selected.
Also when you go to print, there are few options like:
  • Print All
  • Current page
  • Pages
  • Selection
If you attempt to print "selection" without actually selecting a certain portion of the document, you get blank page.
So first check that the correct name of the printer is selected.
Then test printing one page
Hope this will help you. Good luck.
If you find this helpful, please give a rating
luciana44
Please help When I scan a document and save to PDF
Check you scanner settings. Increase the contrast/brightness. Try a good printed page. Clean the glass thoroughly
S. Mohan
5answers
HP All-In-One HP C7280 (Ink Jet Color Printer/Scanner/FAX)
on that web page look if u have any thing which says printable version or printer friendly
try with that and check
Printing problem
Check it's not a software driver fault, uninstall both printers drivers from pc and disconnect the printers and restart. Re-install the driver and then connect the printer when prompted
k24674
Grand Canyon Tech
Grand Canyon Tech
