Kids i think put a code into tv but do not remember the code limited channel access now like two channels
This is how I did mine ; first try to view a chanel that is locked. on the tv front panel turn the volume all the way down with the button, not the remote.While pushing the -volume down on the tv press 0 on the remote .That is it .
I have operating instructions, however, it does not mention how to disable the vchip. If you don't already, this is the contact number for the manufacturers of the product - 18002890980. I hope this is helpful. Good Luck!
If you have a manual try to find, on how to reset your tv to default settings.
1. To use the override code:
2. Hit the MENU key to get to the menus.
3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
OK.
You cannot change Parental
Control settings without
knowing the secret code. If
your code changes, someone
else has altered it and possibly
viewed blocked channels. Yet try the following procedure:-
Philips sets uses a four digit code to contro the V-Chip. The override code for Philips set is " 0711 "
although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
same problem
do not have manule
my kid put a code on the tv and now they have lost the remote as well need help disableing the v chip please help
I can get some channels. On other channels the v-chip pops up and won't let me watch the channel. Please Help!!!
Same thing..
