Question about Xerox Phaser 7300DN Laser Printer
What is error U9? - Xerox Phaser 7300DN Laser Printer
    New Friend:
  • 115 Answers
This error has been detected with the power
supply cooling fan. Do the following steps :
Turn off the printer
wait 15 seconds
Then turn on the printer.
If the problem persists, check the support links at
www.xerox.com/officeprinting/1235support.
Regards
Ashly
Posted on Feb 03, 2010
SOURCE:
Kodak U9 error code. How do you clear it?
we are facing problem Kodak i4600 scanner error u9 .we replaced udds Sensor same problem.
Aug 22, 2013 | Kodak Office Equipment & Supplies
Message erreure U9
U9 in wc group is problem with HVPS. check charge & trf corotrons for leakage. isolate with removing charge or transfer corona each at a time.... U9 disappears; Reinstall HVT. Clean charge corona sawtooth & grid; tighten the grid on charge corona assembly.
Jan 23, 2011 | Xerox WorkCentre Pro 320/315 XL
Unlock motorola u9
Hi friend, you can unlock your phone here http://www.wickedunlock.com/motorola-u9/rs11wp9/ .. You will also be able to get the unlock instructions for it there. Cheers!
Jan 06, 2010 | Cell Phones
The air conditioner wasn't on and the control box was displaying a U9 error
u9 error code means there was a problem with voltage to the unit.Can be caused be either overage or a shortage. Have you had any power outages?
May 12, 2009 | Heating & Cooling
WORKCENTRE PRO 420 U9 CODE
Hello sir; The U-9 code means the main control unit/switch board problem, replace it.
Feb 07, 2009 | Xerox WorkCentre Pro 423 Copier
Rank xerox 5328 U9
if its a u9-1 code it is the lamp that is faulty. Sometimes it can be the connections either end of the lamp but normally the lamp itself. It will probably cost as much to fix as it would to get a new one to be honest
Nov 03, 2008 | Xerox 5830 Copier
Xerox 5328 copier error
U9-3
Xerographic process problem.
The Exposure sensor detected low Exposure Lamp intensity. Switch the Main Power Switch off then on in order to clear the Status Code. Go to the U9-3 Xerographic Process Problem RAP
U9-4
The Main PWB sensed that the Toner Dispense Motor was not running. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP
U9-5
The CSDC zero point was too high during auto setup. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP U9-5 Xerographic Process Problem RAP .
Aug 09, 2008 | Office Equipment & Supplies
Error code U9
hi im jules_09,are you sure its an error code?chek first all sensor on front door and other parts of the copier that has a sensor,
Nov 02, 2007 | Office Equipment & Supplies
Xerox Phaser 7300DN Laser Printer Logo
370 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
