Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
Posted on Feb 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kingston Data Traveler 2.0 64 GB USB - file system corrupted - need to work on windows XP- Upon formatting the pen drive It shows that it has become a raw drive - wat is the file format for the USB to work on win xp? How to rectify this problem. I hav purchased two 64 gb kingston data travelers.... plz assit
  • Anonymous Mar 14, 2014
    I have a 64 GB Kingston Flash Drive. Only 8 GB are recognized. The PC asks for formatting. Windows 7 is not able to format.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1894
Points
5
2gb kingston pen drive showing capicity only 4 mb so pls provide the solution
Anonymous
Level 2:
New Friend:
  • Expert 63 Answers
  • Posted on Feb 03, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
63
Questions
0
Helped
27104
Points
191
They need to be set to 16 bit when you format them
Anonymous
Level 3:
  • Master 813 Answers
Anonymous
Master
Level 3:
Answers
813
Questions
0
Helped
216605
Points
2234
The format should be FAT32 or NTFS, try performing the full format (not the quick format) and then check.
From where did you buy 64 GB of pend drive? Was it a legitimate store as there are many duplicate Kingston pend drives in the market which are actually 1 or 2 GB but have their firmware upgraded to show 32 or 64 GB.
  • Elyk23 Feb 02, 2011
    from where i get the firmware update
1 Related Answer
Anonymous
  • 62 Answers
  • Posted on Apr 06, 2011
SOURCE: Kingston Data Traveler 2.0 64
Theoretically, you can't format a more than 32 GB drive with FAT/FAT32 file system. In your case you have to choose the NTFS file system to format your 64 GB USB flash drive. However, if you really need to format it with FAT32, you got to use the command line or a third party tool. Hope this is going to help you.
Kingston Data Traveler 2.0 64 GB USB - file system corrupted - need to work on windows XP- Upon formatting the pen drive It shows that it has become a raw drive - wat is the file format for the USB to work...
1helpful
2answers
The file system is unknown
The file system is likely corrupted. This can happen if you remove the usb drive from the computer without clicking "Safely remove hardware' first, (in your taskbar).
There is little chance that you can recover the data.
Just in case, try inserting the drive into different usb ports, preferably also on different computers. If the result is always the same, you will have to format your drive.
Insert the drive into a usb port. Assuming you use windows, click Start, click My Computer, find your USB drive in the list and RIGHT click on it. You will see a Format option. Click on that and use default or FAT. A quick format should do.
Good luck.
2helpful
2answers
I can't format my 2gb kingston data traveler 2ntfs and it stores only less than 28 mb. i can only use this data traveler on my microsoft office word and excel files but about my audio files, all could be...
I have kingston datatraveler 200 (64gb) and I backum 4gb`s on that usb, but when I want to opet that, its corrupted, damaged and now I cant even format my usb.. help
1helpful
32 Gb Kingston pen not working
Format the pen drive first, then copy the files.
1helpful
2answers
Usb problem
Is this problem occurring every time? If its first time then i would advice to format Pen drive . Yes if files are corrupted then in properties windows of pen drive its show data empty. Try to format.
31helpful
5answers
32Gb kingston pendrive not working. Any data copied get corrupted
When i copy any data to my 32 Gb Kingston pen drive whether any audio or video file or any software, the data get corrupted or may be deleted. some trimes it happen that some of the AV files are working. Why this happened that the data are deleted. I have lost many of my files due to this.It cannot be fomatted also. Please sort my this problem. Thanx
3helpful
How to format a pen drive?
Try HP formatting tool with administrator previliages in vista
Kingston? USB Data Traveler 101
Hi.
Your pen drive might have got corrupted.
Just format it and the problem will be gone.
Hope this helps.
Regards
Faraz
1helpful
2answers
I know about this problem and the solution.
First, you should know your pen drive is infected with a virus. You can't usually repair it, you'lll just have to format it, and I'm getting to that.
Now, Before you format the pen drive, you might want to preserve some files in the drive?
Instead of trying to view the pen drive by double clicking or right click=>open TYPE the ASSOCIATED DRIVE LETTER at the RUN DIALOG BOX (start=>run)
Eg:
If your pen drive is assigned to drive E:
Start=>Run
Type "E:" (without quotes) and hit enter.
It should open.
Now you will probably see some weired .exe file, probably named fun.exe. That's the virus. You just cant delete it. BUT you can copy the rest of the imprtant files to your hard drive.
TO FORMAT
Start=>Run
type "cmd" (without qoutes) and hit enter
type "format/x E:" (without qoutes and mind your spellings and spacing. REPLACE "E:" with the associated drive letter of the pen drive)
Hit enter.
Hope my info fixes your problem,
Thanx for using fixya.
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
