Plz give me solution for this problem
You have to upgrade firmware to reset scx 4300 printer, after that ur printer is permanently resetted and you can use refill toner forever.
www.nakshatraworld.com
Remove the empty toner cartridge and replace it with a new toner cartridge or a recharged cartridge. New toner cartridges can be purchased from the place where you purchased the printer.
SOURCE: My laser Printer shows a message and do not prints
you can solve its by replacing the Cartridge Unit.
othewise a solution available in my side. You can refill your cartridge until when the cartridge unit damaged.
if you have internet connection i can clear it through internet.
SOURCE: My laser Printer ML-1640 & ML-2240 shows a
Here it is:
http://img528.imageshack.us/img528/7835/reset.jpg
I have tested this on a printer with the following versions:
OS Version - 1.01.00.78
Engine Version - 1.00.49
SPL Version - 5.07
I am using the original initial cartridge.
I think if you want to use a replacement cartridge, you have to disconnect CN5 and short out CN9. This way the toner will always be treated as the initial cartridge.
