Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Judy Bain Posted on Feb 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 6/7 yr. old Whirlpool Topload washer Ultimate Care II I have looked everywhere fior the model number Lid/Back and side. No find!! I need the timer motor for this unit. It is 7 cycle, 5 speed Quiet Wash, Commercial Quality. White in color. The only numbers I can find are: SM8280867, PN3953615, 3357978
Anonymous
Level 2:
  • Expert 254 Answers
  • Posted on Feb 03, 2010
Anonymous
Expert
Level 2:
Answers
254
Questions
0
Helped
90904
Points
735
Open the lid look under the lid middle center on frame or tub the gap bewtween the lid and console....
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1696
Points
I have a top load commercial whirlpool ultimate care ll with extra rinse cycle LSN2000JQ2
it will not advance after the wash cycle on any setting
my washer is setting with a tub full of water
I was given a whirlpool ultimate care II washer recently, and the lid switch is broken, but I cannot find what the model number is for my washer (believe me, I have looked EVERYWHERE for it!), and the part...
Usually the model number is on the lip of the inner rim of the washer when you open the lid...near where the water comes into the basin. But even if you can't find the part number for the switch or the washer, you can just defeat the switch by taking the two colored wires from the switch and twisting them together...no switch needed then!
1helpful
How do I change the dog agits in the ultimate care whirlpool topload washer model lsr8233eq1
Remove number one then 23 then number 2
Then remove the agitator. Set it on the floor and yank it apart. Install the new part being careful not to break the retention tabs on the base of the agitator. Here is a nice video which shows how it is done:
More videos and a service manual are HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2answers
Find serial and model number
Normally on top load machines open the lid and look toward the back hinge area inside the lid. It is usually on the back there. It may also be posted on a white sticker on the back of the machine.
1helpful
2answers
My Whirlpool Ultimate II topload fills with water but does nothing else. The lid switch appears OK
it might look ok but not all the time it is. If the switch is good, maybe it is a burnt or bad connection at the motor. or it could be a bad motor
1helpful
My whirlpool 8525079 topload washer fills with water but does nothing else
Lid switch should 'click' when lid lowered. May need to be renewed if you can't hear this.
1helpful
How to remove back & top of a whirlpool ultimate care II washer
I'm not sure of the model number of the stove but usually slide a putty knife under the control panel between the bottom of the control and the top of the base. There is a clip on each side then the panel will tilt back and you can take it off. After that there are 2 gold clips that hold the back on to the base. Remove them by snapping then out of the base. The the whole thing is loose and the base (where the lid and sides are. Comes out as 1 big piece. If you get the model number from under the lid, you can go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
and it will show you a breakdown of the machine. Let me know if you need anything else.
Whirlpool Ultimate Care II spin cycle not functioning correctly
It sound like the basket is out of balance. When it spins open the lid and see if the basket is moving side to side and back to back. If so look under the deck and see if there is springs or rubber ties attached to the basket.
I can't find the model number on washer Whirlpool Ultimate Care
Model # and info is under the lid. Open lid and look directly under it - area facing you. You should see a small silver tag with all the factory info on it. My washer is also 9 years old.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
