Unable
to save gprs settings in nokia 5300 mobile phone, where configuration
settings are empty. it shows "only 70 sets allowed settings
discarded".\r\nwhen i want to create personal configuration it shows
"can not add new account, memory full". please help me
immediately.........
Follow the following steps to save your configuration settings.
1: Download & install OxyCube. 2: Connect your phone with USB cable. (USB Cable drivers must be installed) 3: Run OxyCube. 4: Select C: (Your phone memory). 5: In folders tree select Omadm Folder. 6: There will be 70 Numbered folders under Omadm. 7: Delete all folders accept first 5 & the folder named PRECFG. 8: Disconnect your phone. 9: Reboot your phone. 10: Either request you provider to send you settings. or insert it manually. 11: This time the settings will save normally.
IN NOKIA 5200 GPRS SETTING NOT SAVE DISPLAY SHOWS ONLY 70 SET ALLOWED nokia 5200 gprs setting when I try to save it will say only 70 sets allowed setting discarded
Dear sir
please i wanted to configure gprs on my nokia 5200 but i cant whenever i enter in to configuration setting the phone will show not enogh memory
ineed your help
In this case,back up your phone memory,remove sim,press *#7370# or *#7780# the phone will be reset.then save your settings for gprs.otherwise you set you setting for gprs manually.
