Question about Casio G-Shock GW300CA-1V Wrist Watch
Does the g-shock illuminator dw-9052 have the option to light up if you flick your wrist fast...instead of pushing the button ?
  • 2,338 Answers
I don't think your watch has this sort of option. You can find out yourself by finding CASIO watch manual link in my tips.
Posted on Feb 02, 2010
SOURCE:
I changed the batt. in my casio g shock dw 5600e and the screen will not light up.
you had to reset it by shorting it, it is located inside your watch. or push all the buttons at the same time. i hope i had been helped you.
Jul 21, 2011 | Casio DW-5600E-1VCT Wrist Watch
I dont know how to set it to 12 hour. for my Casio G-shock 1289 DW-6900CB
Press the "adjust button" until display flashes.By pressing "mode" button
go to 12/24h setting.Press the lower left button to switch between 12/24h.
When finished press the "adjust"button again.
Jan 21, 2011 | Casio G-Shock GW500A-1V Wrist Watch
Looking fo ra parts break down for the DW-9052 Casio. Was replacing the battery and the spring and a little metal tab fell out. trying to find out where they go.
if its a tiny little spring then those springs you will need to put them in a little hole on top of the movement so they press up against the back of the case when y ou put it on . I am not sure what metal tab you are referring to , but I am pretty sure it is the tab that goes on top of the battery and holds it down.
Oct 14, 2010 | Casio DW9052-1V Wrist Watch
Where can we buy replacement watch bands for this watch Casio DW-9052
You can buy genuine Casio watch bands from www.tiktox.com
Check out there website first.You can order online,or give them a call.
Make sure you have measured the shoulder correctly when ordering a new watch band.Your watch model number will help in the search on their website.
Apr 07, 2010 | Casio DW9052-1V Wrist Watch
Casio g shock dw-9052 how to change from military time to standard time
You can get instructions from the Casio web site which will tell you how to set your watch..
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Feb 22, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Spring poppedout on dw 6900 g shock. need a
This happened to mine, couldn't get a spring anywhere. But managed to fix it by using a staple which I cut to size, Works fine now.
Oct 23, 2009 | Casio G-Shock G7000D-8V Wrist Watch
I've changed my battery on my casio g-shock dw 003 but the illuminator no longer works! why?
Did the same with my DW-003 and thought I'd broken the Illuminator (and the alarm didn't work). Next battery change was via a shop and the illuminator worked again (as did the alarm). This was just a battery cahnge, rather than a repair job - One of those things, I guess
Sep 30, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
My G-shock wavecepter is 1 hour fast. I can't seem to get it to set to the proper time. I live in Oregon on in the Pacific Time zone. My watch is set to LAX. DLS is off and when I tried it on it jump to 2...
This url (below) has a REAL manual for your watch, not the worthless one that comes with the unit.
http://world.casio.com/wat/download/en/manual/
You can type in your 4 digit module number and get a great document that tells you how to operate your unit and some of how it works. (Adobe Acrobat - PDF file)
The solution involves holding down the adjust button until the time zone starts flashing, adjusting with the right 2 buttons and pushing the mode button to get to other options. You then finish by pushing the adjust button again.
Hope that helps. :-)
Dec 05, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Manual for casio G.shock DW-5900
How do I replace the battery on a casio wrist watch?
Apr 25, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Casio G-Shock GW300CA-1V Wrist Watch Logo
319 people viewed this question
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
