NorStar M7310 Corded Phone Logo
Posted on Feb 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Meridian M7310; just installed replacement phone (used); line 3 disconnects when answered. Lines 1 and 2 work fine. They are in the loop. Line 3 is dedicated fax incoming but can be used as outgoing phone.
Anonymous
Level 3:
President:
  • Master 3,278 Answers
  • Posted on Feb 01, 2010
Anonymous
Master
Level 3:
President:
Answers
3278
Questions
0
Helped
784539
Points
9440
Normal 0 Hello, Gary.
Disconnect power and cables from all phones and faxes on the line 3. Wait 15 minutes and reconnect the line again, one at a time. See if the Meridian works. If not, it could be faulty.
Hope this helps.
All of a sudden the line lights on our nortel switch Meridian M7310 phones started blinking and the lines are dead. Any ideas?
If you only have one line,why not just lose the Nortel system? You can reuse the wiring from the phone sets to the contoller as regular inside wire,and just plug in regular phones(and maybe put the Nortel phones and controller on EBay and make a few bucks off it!)
2helpful
1helpful
2answers
Hi there ... We have 4 lines in the office but on one of our M2000 series Meridian phones only the first 2 line buttons receive a dial tone ... How do add lines 3 and 4 to the next 2 buttons?
Programming is done on M7310, M7324 and T7316 sets.
To set up line appearence you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program the new lines on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the next key (bottom right arrow) till it says 003:unaaign.
press the chng key till the screen says appear&ring
Press the next key(bottom right arrow)
The display should say line 004: unassign
press the chng key til the screen says appear&ring
press the Rls key when finished
2helpful
Have Norstar M7310 5 line phone 2 lines say they
You need to unplug something, just not the phone.
The two lines are probably conferenced together. Go find the gray Nortel cabinet and pull the plug on it.
Carl
Do you know how to divert calls from Meridian M7310 to a mobile phone?
you can divert calls from lines using line redirection (feature 84) however, it will divert all calls comming in on that line and not the calls going to the phone itsself
External Speed-Dial Default Lines
You have to remove line 4 from appearing on all of your phones.
Login to your system with Feature ** config.
Go to extensions find lines configuration, and set Line004 not in service on EACH extension.
Meridian M7310-shows outside line in use and cannot disconnect
the easist way to reset that is to reset the system. unplug it for a moment that should clear it.
22helpful
3answers
No ring and appear on my Norstar M7310
This should work on M7310, M7324 & T7316
Feature ** 266344 - password 266344 - configuration - line data - line access - show ext (yours) - line assignment ( which lines you have, usually 1 & 2) - show line - appear only/ring/apprear and ring
Hope this helps
Help Request
Do you have any programming experience on your system ? Is seems like the line has to be asigned to the phone it is ringing on but you will have to do that in system programming.
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
