Question about Uniden 5.8GHz Dual Cordless Phone
I have the Uniden TRU9085-3 Series (base answering machine and 3 handsets). I have two sets in the house and want to join them so that I don't have to use both bases ... but when I try disconnecting one base I get message "handset out of range" ... how can I do this?
  • jan_swain Feb 02, 2010
    Agree but how do I do that? I have tried without success so figure I must be missing some step.
To clear the base of all phones.  Missing or not. for the uniden tru9085 3 cordless phone
First deregister any phones that you already have.  You can do it by linking to the base, or you can do the 'remove battery, press key, insert battery' method.
Once that is done:
1. Disconnect ac adapter
2. Press hold dnd ,middle soft key, star key, hold at the same time.
3. Reconnect ac adapter while holding three keys
4. Long beep release button
Done!
Posted on Feb 05, 2010
  • Uniden Master
  • 8,081 Answers
You must register the orphan handset to the base you are keeping.
Posted on Feb 02, 2010
  • k24674 Feb 02, 2010
    Here are the details from the manual.
    1. Deregister from its original base (screen capture 1)
    2. Register it to new base (screen capture 2)
I have a Uniden TRU 9085-3 Cordless Phone and we can not find the manuel. It's dual phones with a base.
The phone ring is very quet so we can't hear it.
How to make the ring louder or where to get the manual. I checked on Uniden Website, they don't have this model.
Thank you
Posted on Feb 14, 2010
SOURCE:
How do I setup a Uniden Dect 5.8Ghz 8155+2 phone
Uniden XDECT 8155 + 2 Questions & Answers ...
www.productreview.com.au > ... > Uniden > Uniden XDECT 81xx Series
Uniden XDECT 8155 + 2: 25 questions and 38 answers on Australia's largest opinion ...and select Handset Setup or Base Setup. ... If you have a 2.4 ghz or 5.8 ghz modelphone use web address below. .... Uniden Premium DECT 31xx Series.
Nov 23, 2015 | Uniden Lands Phones
Base handset has interference.
If you still have a regular phone about, plug it inhere the base handset is connected and see if the symptoms remain. If they do, the problem is likely with your house wiring or the phone company. If no interference on the regular set, base handset may be defective. Try it at someone else's house.
Radio Shack (hurry :) has in-line filters that may clear up line noise.
All he best
Mar 06, 2015 | Uniden DECT2188 DECT 6.0 Expandable Corded...
How does one use the intercom
To Page another phone to initiate intercom:-
From the base station - press Find hs/Intercom.
From a handset - Press Intercom/clear.
Then select the station you want to talk with or All to
page all stations at the same time.
To answer a page:-
From the base station - press Find hs /Intercom or Speaker.
From a handset - press Intercom/clear or Talk/Flash.
Hope this helps
Ive also included a link to the D1785 Series User's Guide
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1785om.pdf
Feb 01, 2014 | Uniden D1785-3t Dect 6.0 Cordless Phone...
How do i turn off the silent mode on a uniden phone, ive held down the # sign and nothings happening
Silent Mode
You can silence the ringers on the base and all handsets for a specific period of time; the answering system answers any incoming calls without playing anything through the speaker.
With the phone in standby, press and hold # on any handset. The phone prompts you to select the number of hours (1 - 9 or Always On) that you want it to stay in silent mode.
To confirm, press # or just wait about 5 seconds. The phone turns on the answering system and displays Silent Mode On on each handset.After the selected number of hours, the phone automatically exits silent mode. To exit silent mode manually, press and hold # again.
If the phone is in silent mode and you turn off the answering system, the phone exits silent mode.
Multihandset Features To use the features in this section, you need at least 2 handsets.
Your base supports a total of 12 cordless handsets: the one that came with the base and up to 11 DCX160 accessory handsets.You must register accessory handsets to the base before using them. (Handsets that came packaged with the base are already registered.)Handsets that aren't registered display a Not Registered message. For registration instructions, see p. 18, or see the accessory handset manual.If a handset was ever registered to a base, you must reset it before it can register to a new base; see p. 18, or see the accessory handset manual.Conference Calling
When an outside call comes in, two handsets can join in a conference call with the outside caller.
To join a call that's already in progress, just press Talk/flash or SpeSpeSpeaker.To leave the conference call, hang up normally; the other handset remains connected to the call.
Aug 18, 2011 | Uniden DECT 2080-5 Quint Phone
Uniden 6.0 answer/base/ cord less message set up
Thanks for using FixYa.
Please let us know the complete model number of the phone.
May 15, 2010 | Uniden DECT 6.0 Cordless Telephone...
Two sets Uniden phones with base, second handset: incompatible?
I had the same problem with a Uniden 3355 handset and 2355 base. With the new handset I pressed "Menu" and selected "System Reset". I then Selected "Deregister HS" and followed the prompts.
Once this was complete, I returned to "System Reset" and selected "Replacing Base". Following the prompts, when it said "Register Handset" I put it in the base of the 2355, and within a minute it had registered, so both handsets used the base of the 2355!
S.
Jan 09, 2009 | Uniden Cordless Phone
How to set up uniden phone to base
If the handset has previously worked with the base - press the hangup button and the # key at the same time on the handset for five seconds and follow the prompts to deregister the handset. (System reset - deregister HS - which handset) It will tell you that the handset is deregistered. Then put the handset onto the base and it will register the handset.
Dec 14, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
Uniden powermax 5.8 handset
place both handsets on the recievers for 24 hours so they can register to there spots
Dec 28, 2007 | Uniden TRU8885 Digital Answering Machine
Uniden 5.8GHz Dual Cordless Phone Logo
991 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
