Question about Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140
Battery Issues I have two Makita Lithium Ion 18V 1.5 ah batteries (Model BL1815) that won't re-charge. I've cleaned the terminals on the batts and the charger...none of the batts have been dropped, etc. and they are less than one year old. When I put them in the charger, it beeps and flashes red and green, etc. Anything I'm missing here?
  • 7 more comments
  • Anonymous Mar 12, 2008
    One of my batteries (BL1815) will not charge. Replaced battery once, a couple months later, same problem. Charger flashes red/ green. Other battery charges fine.
  • Anonymous May 06, 2008
    Exactly the same
  • Anonymous Dec 08, 2008
    Tried recharging with a pair of 100ohm resistors from a good battery, even up to 17.3 V, it would not take a charge, I think the Battery may have a EPROM chip that tells the charger "NO",
  • Anonymous Jan 06, 2009
    Nearly new Li-ion battery will not charge, no problem with other batteries on the same charger.
  • ngundy48 Jan 14, 2009
    I have a Makita 18 v li ion batteries and both will not charge anymore. i thoought it was the charger because they both did the same thing as above at the same time. The new charger did not make a difference. Both batteries will not charge something is wrong with this pix.
    Norm
  • majorhangove Feb 12, 2009
    Got four batteries the first two have died after 12/18months respectively, two slightly newer ones still working, red green lights alternating and beeping on charger!
  • Anonymous Apr 29, 2009
    This is common with the Makita BL1815's they die after 50 to 100 charges.  Good luck sending them back to Makita, I got the run around from both the the Home Depot I bought them at and the Makita Service. Center.  Great drill when the batteries work, when they work.
  • Rob123 Jan 02, 2017
    I found this really good solution:https://youtu.be/vuGIkkYFt5g
  • Rick Labus
    Rick Labus Jul 20, 2017
    Unfortunately mine would charge and then discharge rapidly. Charge would not hold
    Problem Solver:
  • 3 Answers
When Li-Ion batteries are discharged to a too low voltage (below 2,75 V/cell, in this case 13,75V) the charger will assume that the battery is damaged, and will not charge the battery. First measure the battery voltage with a volt meter, if the voltage is significally below the 13 V the battery are no good. If you have a reading of lets say around 10 V, you can raise the voltage shortly on the battery, by jumping it with a fully charged battery. Connect the "-" poles on each battery. After this, shortly connect the "+" poles, for no more than 5 seconds,disconnect the wires and immediatly put the battery in question in the charger. If it starts charging, every thing if fine. If not, try the process again, you might wanna recheck the voltage if it rises.
Please be aware, that over discharging Li-Ion batteries, will lead to damage of the Li-Ion cells, which results in loss in capacity, therefore, if you are not to use your Li-Ion tools for a while, make sure the batteries are fully charged.
Hope you guys could have sucess with the above
Best regards
Soeren
Posted on Jun 28, 2008
  • 9 Answers
Some solutions for Makita battery issues. Your milage WILL vary.
If you have been a bad boy and managed to short the battery by using it for non-proscribed purposes, or it just shorted for some other reason (like stalling the drill repeatedly)  the fusible link will blow (kind of like a fuse)
To fix it, open up the battery (use a Torx 10 security bit, or a small flathead in a pinch) On the battery connection nearest the spring-loaded white catch there is a small bridge of metal with a hole in the center. If this is melted you can solder it back together by sanding the two pieces and putting a glob of solder on them. This will void your warranty (duh!) and remove the battery's fuse protection, but it WILL work again.
If the link is intact and nothing else is obviously wrong, you almost certainly have a bad cell. I recommend pulling out the bad cell ( it will be the one that does not read between 2.5 - 4 vdc) and replacing it with one from another dud battery- this requires some fudging and re-soldering.
Or do what I did, pull the cell, toss the electronics and the short pink wire, add a cigarette lighter socket and voila! you have a portable power supply giving around 14 volts. Charge it up by wiring two cigarette lighter male ends together (check polarity , + to + and - to -) and plug it into your car, but only while it is running or you will be charging your car battery with it!
Hope that helps.
Matt Binns
GiantGlobes.com
If your battery reads well below 10-12volts….
Try charging the battery with a car charger set on low (2 amps max) or a wall transformer from a phone or some such with a 12vdc output (make sure it is 12vdc not 12vac) You will need to know which of the charger wires is pos and neg, be careful not to short the battery as this will blow the fusible link. Connect + to + using jumper clips or stiff wire jammed into the battery contacts.
Once you get the battery over 10-12 volts the charger will normally accept the battery.
You can jump one good battery to the bad to do this, but in all cases watch out that the wires do not get hot, as this is a BAD sign, often a minute or two will be enough.
Of course you may have a dodgy charger, they are not robust at all.
The fans also ****, noisy and sometimes they quit, causing the charger to quit too
Matt Binns
GiantGlobes.com
Posted on Aug 18, 2009
  • bigmack56 Feb 05, 2011
    Look folks, here is the deal.. And a LOT of folks do this (like DELL laptops for one...) The deal is a small printed circuit board inside the battery housing. I took one apart to see if it gave me any clues. I found the chip manufacturer, and I can see the reset line, but aparently that is NOT enough. The chip is designed to remember specifics about the battery, and, I don't believe they would be using MEMORY on the chip UNLESS they were COUNTING the number of charges/discharges and then setting a flag telling the 'smart charger' to no longer supply voltage to restore the Li-ION batteries. I tried wiring around the circuit and the batteries will hod a charge long enough foe me to test it. I would NOT ever rin the batts witout the chip installed, PERIOD. The bats can be had on EBAY for around $50 and if you really do use them a lot consider the BL1830 (bigger but twice the capacity, and the charger is designed to charge the larger batt as well.
    Good luck, I love my Makita cordless, I HATE 'smart' batteries...
    New Friend:
I had the same problem. If I knew makita had this issue I would have bought Dewalt instead - Makita is throwing their name away with these "smart" batteries and chargers. anyway this is what I did...... remove top half plastick cover of battery - leave the cct board as it is or throw it in the dustbin - drill 6mm hole at the back of bottom half plastic cover - pull in twinflex cable - solder it to the positive and negative output terminals of the battery PACK (where you get 18 V) - solder other ends of twinflex to nokia (or similar) charging socket - make sure about your positive and nagative (normally inner pin is positive and outer pin is negative) superglue charging socket to back of the battery so it is nice out of the way - buy an universal laptop charger - the one I have can produce 5.5 A between 12 V and 24 V. so now if my battery goes flat I simply take my universal laptop charger - plug it into the wall or car's cigarette lighter socket, let it charge for 25 minutes and the tool is working again. eeeeeeseayyyy!!! I have the sds drill with the jackhammer selection as well as the grinder. I put up my entire electric fence with that sds drill, jack hammered the concrete underneath the electricity box whe I had to pull in a new cable to my house and also fitted a couple of winch anchor point on my garage roof - all with that SDS drill. just a shame Makita screwed up big with their smart batteries - if some asks me what to buy I will rather tell them to buy Dewalt or similar - unless they they modify their makita batteries - then Makita is fine too.
Posted on Dec 03, 2012
  • mrmx Dec 03, 2012
    I forgot to mention to just set your universal laptop charger to 18V or whatever voltage you need
    Problem Solver:
  • 15 Answers
Less than one year since made or bought? 3 year life on lithium ion batteries, regardless of use. seeing as how both 1.5ah batteries are dead, they most likely fell below there minimum discharge point in storage.
Posted on Oct 10, 2009
    New Friend:
I just charged mine with the car charger and they are working fine. Will see how long they hold the charge.
Posted on May 18, 2017
    New Friend:
Try a youtube search for the explosion of li-ion cells that have been overcharged, before you remove safety features of the battery and hotwire it! Yes the battery is poor, ditch the tools for another brand!
Posted on May 05, 2013
SOURCE:
Can you fix a lithium battery?
The Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 us the BL1830 battery, there are several types for it, 1.5Ah, 3.0Ah, 4.0 Ah. Maybe 5.0Ah battery for it will be available. And, the inside of the BL1830 uses the 18650 battery cell. If you have a good knowledge and skill about electronic, you can buy some 18650 cell to do it yourself. If not, I suggest you to buy a brand new one.
You can buy some original battery for replacement battery for Makita BTD140 Battery
Jun 09, 2014 | Makita 18V LXT Lithium - Ion Cordless...
18v lith ion Battery charger 12v makita will not charge battery? why? why?
I also have the same dilemma,and of course,it occured 1MONTH after 1year warranty expired.I know my batts r still fine,as I recharge em on my foremans kit.
My charger plays a tune,then just blinks red,green....etc.Wish I had some tips to try,from an electronics brain-type person.......lol,good luck::
May 11, 2014 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Bl1815 wont charge
i bought a new makita cordless drill in united states of america brought it home to the republic of ireland got a 110 adopter to recharge the battery but it will not hold the charge would it be the flight home have wiped the batterys what do i do?
Feb 07, 2013 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
One question please, I have makita cordlless
according to the schematic I saw yes you can and I think that you will be pleased with its performance, their operator manual even lists the weight of tool with this battery. Makita has a 1 year limited warranty on the Li-Ion battery that you might want to consider if you have the receipt.
May 11, 2011 | Makita 18V LXT Lithium - Ion Cordless...
Makita 18v lith ion battery not charging
Push the battery in and out while pressing the trigger on the the drill to see if there is a loose connection here.
Check the battery terminals inside the drill and the battery terminals .These sometimes become tarnished and don't make contact. Clean with very fine sandpaper or wire wool. Apply light pressure as otherwise you may remove the chrome or nickel plating on the contacts.
Apr 04, 2011 | Makita BDF452HW 18V Cordless Lxt Lithium...
When putting the battery in the charger the red and green lights flash indicating a bad battery, cannot charge battery.
Have you tried just waiting a few minutes, it might start to charge anyway. But if not, is there some reason you would assume that you don't have a bad battery? There are lots of bad Li-Ion batteries.
Sep 03, 2010 | Makita BL1815-2 18 Volt 1.5 Ah Compact...
The Makita BL1815 battery will not charge, lights flash red/green, indicating bad battery. I replaced one open cell with known good cell, charger still reads bad battery although I can charge from an...
tried it a few times. got the charge up to around 13.9 and it still wont charge. i dont understand, because the battery isnt that old to begin with. thanks for the suggestion.
Dec 16, 2009 | Makita BL1815-2 18 Volt 1.5 Ah Compact...
Makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Feb 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 Logo
23,916 people viewed this question
Top Makita Drills Experts
John Trevino
Marvin
Marvin
Spud Howell
Are you a Makita Drill Expert? Answer questions, earn points and help others
