Samsung Q1 Ultra Tablet PC Logo
Posted on Feb 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung q1 bios password reset - how? - Samsung Q1 Ultra Tablet PC
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2177
Points
Why cant i change my bios password for my samsung np-q1
SANJEEV KUMAR SURI
Level 2:
Guru:
  • Expert 170 Answers
  • Posted on Feb 01, 2010
SANJEEV KUMAR SURI
Expert
Level 2:
Guru:
Answers
170
Questions
0
Helped
54890
Points
491
MASTER RESET PASSWORD OF SAMSUNG PHONES: 0000 (FOUR TIMES ZERO)
THANKS ALOT,
SANJEEV KUMAR
How to fix not working touchscreen? Do i have to replace it?
The Samsung Q1 is a hybrid, ultra-mobile, touch-screen device that is basically a very small tablet PC. It features a 7-inch screen, weighs a mere 1.7 lbs., features a Windows operating system, doesn't have a built-in keyboard, and comes in a variety of configurations. The Samsung Q1 doesn't offer outstanding battery life, but you can make some moves to boost your computing time.
Dim the Screen
Dim the screen brightness. Four programmable application-launch buttons occupy the right edge of the Q1. One of these, the menu button, calls up frequently-used controls, including screen brightness. Reduce the screen brightness as much as you can, as it's one of the best ways to extend battery life.
Close Power-hogging Apps
Close applications and browser windows when you're done with them. Too many open programs drain the battery. Beware power-hogging apps. Watching a video or listening to music on your Q1 drains your battery life much faster than just using Microsoft Word or checking email. Turn off the Wi-fi networking when not in use. The built-in Wi-fi searches for a network when you're not connected, which drains battery life.
Properly Caring for and Feeding a Battery
Unplug the Samsung Q1 after the battery is fully charged. Leaving your Q1 plugged in 24/7 leads to some discharge from the battery. Consider buying a bigger battery. A 3-cell battery comes with most configurations of the Q1, but you can also buy a 6-cell battery to double the battery life.
Room Temperature is Best
Don't expose the Q1 to harsh conditions. Keeping the device in a blazing hot car in direct sunlight harms your battery life. If you use your Q1 in conditions above 95 degrees Fahrenheit, you can permanently damage the battery. Cold conditions don't harm the battery in the same way, but if you leave the Q1 in the cold, let it warm to room temperature before you use it.
I hope you find it very helpful. Best regards.
1helpful
I cannot adjust the brightness of my samsung N150 plus mini laptop
me too, same problem...going into the bios and changing to user controlled makes no difference, also changing the power settings makes no difference - even if unplugged.
anyone know?? much appreciated
LOST MY PASSWORD AND TRYING TO GO IN SAFE MODE TO RESTORE TO EARLIEST DATE BUT IT PASSWORD PROTECTED CAN I DO THIS ANOTHER WAY
Insert OS installation disc, boot from it, select language, then select repair. Use the system restore from here to restore. It will not ask for a password.
Hi i have a samsung NP-Q1 tablet pc. I have forgotten the windows password and cannot get in. I do not have a external Dvd drive and cannot use any cd's. Is there a way i can use a standard usb stick and...
Yeah! You can. As far as I know, third party software Windows Login Recovery is used to reset forgotten windows password and the windows password reset file can be stored in a USB flash drive.
I need to install an operating system on a Samsung q1 ultra
Suggest you use an external DVD drive, and put your installation disk in it. Then access the BIOS Setup utility.
In BIOS Setup, find the Boot Order menu. (Generally, along the top headings of the main menu, in BIOS Setup, or located in Advanced BIOS Settings) Set the first boot device to be CDROM. Be sure to Save your change.
This way the handheld, will boot from the installation disk, in your external DVD drive.
Should you be trying to downgrade from Vista to XP, you have to change the first boot device, in Boot Order to CDROM. If not, Vista won't let you overwrite it.
Vista is an upgrade over XP.
Samsung Q1 wireless netowkr switch?
There is no wireless switch for the Q1. Go to "network connections", "right click" your "wireless network connection" and then click "enable".
Autoscaler no longer works on my samsung Q1
The function is assigned to the key by a preloaded software. I suggest you reload your "system software media" which is on one of the two DVDs which come with your Q1.
4helpful
5answers
Forgot password -samsung q1 ultra
Have You Lost Your Windows Admin Password?
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press <ctrl>+<alt>+<del> keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
Administrator lock
Do a 'light' reset using the reset key of your Q1.
2helpful
Black screen at power on
I had the same problem. I pull of battery and then immediately reattached and ta-daaaa! Windows came right up!
Hope this helps!
gg
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
