Ovens Logo
Posted on Feb 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Knob on oven is not working properly
The knob on my oven just keeps spinning around and i cant cut my oven off.
Barry Coates
Level 3:
  • GE Master 3,463 Answers
  • Posted on Feb 01, 2010
Barry Coates
GE Master
Level 3:
Answers
3463
Questions
Helped
1406953
Points
12766
The knob is probably cracked, if you can pull it off, then you can try to see if you can turn the oven off with a pair of grips or pliers, if you can, then you just need to replace the knob, if not then you will have have to replace the switch.
1helpful
Just moved and have diplomat built in single elec oven checked inside but cant find model or serial no. 2 knobs on left all symbols gone some push buttons middle and knob on right numbered 1 to 5
Hello -
Please double check for the model number. It will probably be on a small metal plaque on an edge of the oven door, along the outer edge of the oven opening, or in the oven interior. It could also be on the top of the oven and covered by cabinetry.
Undo the screws that hold the oven in and slide it out 6 inches. You may then find the metal plaque on the top of the oven. You may need the help of another person when you try to pull the oven out, so that the oven does not tilt forward and fall to the floor.
You MAY be able to identify your model of Diplomat oven from one of the images of Diplomat oven control panels here:
https://manuall.co.uk/diplomat-select-620-oven/
Page 6 (PDF document image 7). Note: Use the + icon to enlarge the image.
You may find the image of Diplomat oven knob markings here helpful:
https://www.ukwhitegoods.co.uk/forums/forum/public-support-forums/help-and-support/cooker-and-oven-forum/61498-diplomat-adp4890
Scroll down that page to the post dated 14-12-14 from pslewis333 to see the image.
Once you know which model of Diplomat oven you have, you may be able to find and purchase decals with the proper knob markings for your oven so that you can affix the decals around your oven knobs. Or, you could use heat resistant paint and a small, pointed paint brush to paint the markings on your oven. With either option, I suggest you seal the markings with a heat resistant clear sealant so that cleaning / scrubbing will not erase the markings.
Best wishes.
Jan 24, 2019 • Ovens
1helpful
Both oven knobs have come off and although don't appear to be broken we can't seem to fix them back on properly
First try a layer of silver paper around spindle.
If not satisfactory then try a "No nails" type of clue.
I have a stove built in oven and had a power cut and it keep flashing 8888 and wont work
Hi.
After power cuts most ovens need resetting, for this reason 00:00 is flashing. The operation is described in the specific model's user manual. Most ovens reset either pressing or holding down for few seconds a Clear or On button, or holding down the main control knob.
Aug 06, 2011 • Ovens
Brief power cut but, timer light did not come back on. Cant use main oven. Top oven fine,isthere a trip switch?
Hello everytime the power goes off & then comes back on my oven won't work until I turn the knob for the timer around as far as it will go then back again. My oven is rather an old type but maybe if you reset the timer or turn it that may help. Or check the meter box as well. dee
Dec 27, 2010 • Ovens
I bought a new 4 burners gas. i tried to power the oven section because i wanted to bake cake, but it is not responding
Is the oven gas, if so you may find that it is fitted with a thermocouple (safety cut out) and to get the oven working you need to hold the knob in for around ten seconds after the oven is lit to activate the safety device. If it has a clock timer check it is not on auto and the time is set 'cos that will also stop the oven working.
All the best, pls leave feedback or repost with further information.
Aug 24, 2010 • Ovens
1helpful
Oven does not turn off completely
You should pull the knob off and check that there is a metal liner in the knob itself. These sometimes fall out and the plastic knob does not turn the control properly. Get a new knob at your local appliance store.
Jan 20, 2009 • Ovens
Older gas range not heating up enough
Pull the knob off of the oven control and see if their is an ajustment. If the ajustment doesn't work then change the thermostat bulb. It goes for the oven to the back of the oven control know
Dec 21, 2008 • Ovens
I have an AEG cooker but the marking around the cooker knobs have
Hi.
You need thermostat knob and main oven control knob.
Nov 19, 2008 • Ovens
2helpful
2answers
Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Jun 26, 2008 • Ovens
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
